wires from local auto parts?
JonnyRotten
can I get spark plug wires at local auto parts or do I need to order triumph wires.If so does anyone have crossover #s.1960 tr3a.
tinman58
You can get them at mostt local auto stores. They will have to order them or you can get a set of wires and cut them to lenght. Bring in your dist. cap for the proper dia. Thays is what I did, I got the pretty blue color, with high proformance written on the box. It makes your TR go faster. The best part is you do not have to wait.
dklawson
The last set of wires I bought for one of my LBCs was an 8mm Accel brand kit (black wires) for a Chevy V8. The kit was purchased at my local Advance Auto and came with enough wires, terminals, boots, and the crimping dies to make at least two complete sets of wires... plus some left over. I've been very happy as the kit allowed me to make the wires the right length for neatness.
PeterC
The 8mm wires are too big for the TR3 cap. I recommend the Bosch solid core 7mm universal wires.
Peter
TR3driver
Great Pumpkin - R.I.P
If you are using the original style TR3 distributor cap, I would recommend staying away from the common "carbon core" wires. The TR3 cap uses screws that pierce the insulation and conductor, which work great with the original copper core wires. But my experience has been that the carbon core wires don't like being pierced that way, and will eventually start to burn out around the screw. The damage is invisible, and makes the engine run poorly for no apparent reason (especially in damp weather).
The holes in the cap are also too small for 8mm wires like those Doug mentions.
You also need to pay attention to what kind of terminal is on the ignition coil. The original coil uses a screw-in connection that needs a plastic nut on the wire, and a flat washer soldered to the end of the wire. A push-in terminal may appear to work at first, but won't make good contact with the coil terminal, leading to more poor running problems. However, most replacement coils do have push-in terminals.
One workaround for these problems is to substitute a cap from a 66-70 MGB, which fits the TR distributor perfectly, but takes ordinary push-in terminals for the plug & coil wires.
Sorry, I'm no help with what to buy. I got a set from JCW several decades ago now that still work great, but they are apparently no longer made.
C MGB New plug wires and distributor cap MG 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
K TR2/3/3A Distributor internal wires? Triumph 5
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
R Ground wires under dash Spridgets 5
K TR2/3/3A Testing spark plug wires..... Triumph 11
steveg TR6 TDC - Position of rotor and wires Triumph 4
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
steveg Cobalt top entry wires question Austin Healey 47
69MGC MGC What are these connection wires? MG 6
P TR6 Purple/Red wires & mystery bulbs Triumph 17
69MGC MGC Chrome Wires for my C MG 11
M TR2/3/3A Two black wires on control box E where do they g0 after alternator conversion? Triumph 9
M TR4/4A TR4 door glass spacer wires. Triumph 1
DerekJ Lighting circuit - the smoke's escaped from the wires.! Austin Healey 12
D TR6 Rats nest of wires Triumph 3
2billydavies TR2/3/3A Question about front turning blinker wires Triumph 12
Got_All_4 Wedge Tr7 windshield factory windshield wires Triumph 3
J General Tech I Need a Set of Plug Wires! Help! Triumph 14
JFS TR2/3/3A Stator Tube Wires Triumph 9
W connecting distributor wires Austin Healey 2
T TR2/3/3A Is there a good way to manage all those wires/connectors for headlights & park lights Triumph 9
R BN7 Coil Wires Austin Healey 3
matttnz TR6 Brown wires multiplying Triumph 12
KVH TR4/4A Burned Wires Under the Dash Triumph 2
O TR2/3/3A TR4 Wires to TR3 Triumph 11
T TR2/3/3A Stator tube, wires stuck Triumph 15
Keith_M XJS 12 cylinder wires, cap, and rotor Jaguar 7
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
drooartz MGB Which plug wires go where... MG 5
Rut MGB wires on a Midget Spridgets 6
PatGalvin TR2/3/3A TR3 tires for wires Triumph 2
B Ignition wires to use with Pertronix distibutor Austin Healey 9
richie Ignition leads/wires Triumph 8
B MGB 1978 MGB 2 wires hanging under the dash to the .. MG 4
C Tires on wires Triumph 33
M Restoring proper order to spark plug wires Triumph 36
R Ignition wires Austin Healey 5
I TR6 TR6 heater blower wires -what are these wires for? Triumph 8
wingsandwheels TR6 green plug wires, '74 Tr6 Triumph 6
JohnnyO Dist cap and plug wires Spridgets 6
A Running wires to the door ... Triumph 4
RickB Weird DPO wires heating up really hot Spridgets 16
