Keoke the go to guy. And usually the first to offer help
Here's a break down:
1. Remove the headlight.
2. Remove the turn signal (s)
3. Bend all the tabs straight that hold the beading on.
4. Remove all the screws, found in the following access areas:
Front wheel well
Through the engine compartment
From under the dash
Sockets and wrenches are needed.
The fun part is seeing how limber you are trying to get to the screws from the engine compartement and under the dash.
You may or may not find some sort of sealing material (dum-dum) sealing the stainless bead against the wing or shroud.
Good luck and have fun
