TR4/4A Wing installation
Rut
I’m sitting here reveneering a TR4a dash and for some reason I started thinking about installing the wings back on a TR4a. My cars never sit out in the rain, but I’ve seen so many with rust along the top of the wings that I’m wondering if they should be sealed? My plan is to epoxy prime and topcoat both sides prior to installation and I’m thinking about using the 3M butyl rubber caulk that comes in round strips between the wing and tub in reassembly. Has anyone used this product for this purpose and is it a good idea? I really want to hear your thoughts on this.
Thanks, Rut
Subject has be beat around on TR3 wings as well. I epoxy prime and use body color acrylic enamel on all the underside parts before bolting together. Have never used any type sealer between fenders and tub. To me it will help hold moisture. I like the idea of water being able to drip on though when I wash the car. Just my two cents worth.
Marv
charleyf
I agree with Marv. If you paint the parts before assembly you should be protected. Having taken apart several TR's it appears that they were assembled and then painted. So that places you are worried about did rust because they were not painted to begin with.
Rut
Rut
Thanks guys! With improvements in paint technology and epoxy primers I agree with your comments. On the Bugeye I used Eastwood’s internal frame coating in the sills, spring boxes, and shut areas as well as epoxy primer and urethane topcoat on the rest of the car. I’m also considering re routing the drains that empty into the front wing area and addressing any other problem areas including the frame on the 4a.
Thanks, Rut
charleyf
Rut;1072837 I’m also considering re routing the drains that empty into the front wing area and addressing any other problem areas including the frame on the 4a. Thanks said:
Rut,
I went to the trouble of rerouting the drains behind the front fenders on one of my cars. Then I started looking at how much rust was actually found behind those places in the front fenders. The answer was virtually none. So with the second restoration I did not reroute the drains. I say it is not worth the effort . The only water that is going to get into that area is from the vent if it is open while sitting or driving in the rain. Or if you have a leak around the wiper arms.
fpstude
Okay, I have to ask. What is a wing?
SASSAMON
Perry,
Ask questions and we will answer!
We often use the original words and phases that go with our Little British Cars. They are often found when reading original documentation. Knowing the terms will help in understanding and following instructions.
LBC Wing is US Fender.
LBC Petrol is US Gasoline or fuel.
LBC Bonnet is US Hood.
LBC Hood is US Convertable Top. You can begin to see where confusion can come from.
LBC Boot is US Trunk.
Many others in use. There are lists of LBC to US translation. I don't have one handy to share but I am sure one of the other members will provide a link to one.
Rut
Rut
Perry,
Two countries separated by a common language!��
Rut
fpstude
Thanks, SASSAMON. I've added to my international knowledge.
jimstr4
I probably only drove the TR4 6 times in the rain in 33 years so there's very little chance of water getting in between my front inner and outer panels.
Jim and the 1962 TR4
Tinkerman TR2/3/3A Rear Wing installation fun................... Triumph 3
Tinkerman TR2/3/3A TR3A Rear Wing Clamp Installation Triumph 14
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
H TR4/4A Fender/Wing repair how to do Triumph 5
K TR2/3/3A Wing mirror replacement again... Triumph 0
B Wanted Lucas wing mirror Other British Classifieds 1
S Rear Wing Fit Austin Healey 4
B Wanted wing windows gt6 Austin Healey Classifieds 0
71TR6 TR2/3/3A TR3A Wing to Apron Mismatch Triumph 9
JFS Wedge Door wing window finisher Triumph 2
M Wanted Bj8 left front wing Austin Healey Classifieds 3
D TR2/3/3A Wing nuts for gauge panel on TR 3 Triumph 10
UltimateQuestion GT6 GT6 Mk3 rear wing removal Triumph 3
S Bakerlite Wing Mirrors Other British Cars 2
D Wing Fender Fitment Question Austin Healey 6
F TR2/3/3A Front inner wing baffle measurement Triumph 7
JimLaney Drain holes relieve wing water retention? Spridgets 3
Griz Wing Mirror Location Austin Healey 31
CJD TR2/3/3A TR2 Wing Beading Triumph 24
Rut TR4/4A wing patch panels Triumph 5
S Aluminum wing vents for BT7 3000 Austin Healey 1
Tinkerman TR2/3/3A TR3 A REAR WING BOLTS order of assembly? Triumph 3
Tinkerman TR2/3/3A 1960 TR 3A Rear Wing Attachment Triumph 13
A Aligning New half front wing, outer sil and rear wing Austin Healey 5
GTP1960 TR2/3/3A New left front wing body panel from TRF? Triumph 11
F J hooks an wing nuts for attaching hard top to body BT-7 - anyone got photos? Austin Healey 5
K TR2/3/3A The "brass wing nuts" rhat hold the instrument panel on...... Triumph 2
DerekJ Removal of front wing Austin Healey 15
Rut TR4/4A Amco wind wing repair Triumph 7
Tinkerman TR2/3/3A Front wing question Triumph 3
Tinkerman TR2/3/3A Rear wing fixing clamp Stan Part # 602167 Triumph 5
N Fender [wing!]??? Spridgets 7
Jeepster Wing/fender chrome side flashes Austin Healey 15
P BJ8 wing and panel fixing help? Austin Healey 3
Jeepster Front wing flash fixing holes Austin Healey 5
AH100M Why weren't sill and wing flanges painted black on BN1s and BN2s? Austin Healey 12
PatGalvin Front Wing Sealer Plates Triumph 5
healeyblue Side screen wing nut Austin Healey 7
B rear wing mounting on my 57 Triumph 5
M Home on a wing and a prayer Triumph 16
H wing mirrors Austin Healey 11
B TR2/3/3A Fitting the front wing 57 TR3 Triumph 2
Jeepster wing beading Austin Healey 7
B TR2/3/3A Advice on inner wing removal TR3B Triumph 1
jlaird Wind wing hinges. Spridgets 13
Jeepster Wing removal Austin Healey 6
C Wing wind Deflectors Triumph 10
B MGB 1971 MGB Wing or Fender removal. MG 2
