TR2/3/3A Rear Wing installation fun...................
Tinkerman
In my rear wing installation kit I have 5 screws that are black. Are they to be used to fasten the wing inside of the boot lip?
Thanks, Tinkerman
Don Elliott
Make sure they are not hex head bolts or they will distort the trunk lid when the hex bolts hit the paintwork inside the lid.
They must be truss head screws with a very shallow dome about 1/2" diameter across the domed head. The threads are usual 1/4"-28 UNF.
sp53
What I do on those re-wings if they do not fit is get a couple of bolts started then take some balling wire and put that through a bolt hole and loop the other end around the axle. Then take a wrench or something and put that in the loop the spin the wrench until the wire pulls things down and into place then put bolt in adjacent hole and cut the wire free.
A picture would probable help if you are not use to wiring and banding, but sorry to say I did not take one. Perhaps a google on balling wire and pulling concrete forms and scaffolding together would help if I am not clear.
Tinkerman TR2/3/3A TR3A Rear Wing Clamp Installation Triumph 14
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
S Rear Wing Fit Austin Healey 4
UltimateQuestion GT6 GT6 Mk3 rear wing removal Triumph 3
Tinkerman TR2/3/3A TR3 A REAR WING BOLTS order of assembly? Triumph 3
Tinkerman TR2/3/3A 1960 TR 3A Rear Wing Attachment Triumph 13
A Aligning New half front wing, outer sil and rear wing Austin Healey 5
Tinkerman TR2/3/3A Rear wing fixing clamp Stan Part # 602167 Triumph 5
B rear wing mounting on my 57 Triumph 5
mountainman TR2/3/3A TR3 Rear Wing Bead Triumph 17
D Front and Rear Wing Fitting Austin Healey 2
TR6oldtimer TR6 TR6 rear wing to rear deck fit. Triumph 4
milemarker60 Rear Wing Baffles??? Triumph 4
Lin Rear Wing [fender] fasteners Austin Healey 1
D Wedge TR7 rear spoiler/wing Triumph 2
Lin Rear Wing mounting Austin Healey 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
