TR2/3/3A TR3A Wing to Apron Mismatch
71TR6
I'm doing the final fitting of the sheet metal of my TR3A and discovered the right wing has a 3/8" mismatch on the radius where it meets the front apron. The rest of the wing fits fine and the left wing fits perfectly. The front apron is not the original that came with the car but is another that I picked up after I initially fit the body panels during reconstruction. This new apron is in much better shape than the original and does not have any damage. Secondly, I have reason to believe the right wing is not original since there was pretty significant damage I had to repair on the right front suspension.
Any thought or recommendations on how to correct this? 3/8" is a lot of body filler and I'd prefer not to go that route if there's a way to minimize the filler.
Ron
bobhustead
I don't recall how much mine were out, but I was able to align the pieces one bolt at a time and clamp them with the bolts as I went. Try algning the center first and use the leverage toward the ends as you work out. The beads will hide a lot of the remaining misalignment, which should be fairly small.
Bob
James Christie
A word of encouragement, that‘s not a mismatch, it just needs adjustment! In fact it’s pretty good compared to most.
Follow Bob’s suggestions (except I would start at the top where the bonnet/hood fits and work forward). Some judicious pushing and pulling will get it right. Wedges of wood between the apron and inner wing may help. You may have to enlarge a few bolt holes too.
james
Jim_Stevens
Agree with the previous two posts. I think mine was similar, but with an extra set of hands and eyes, it went in. Don’t forget to take the bumper brackets into account too! The good news is that yours is still in primer, so adjustments can be still be made.
CJD
You may also need to snip the bolt holes to allow a bit tighter radius if needed. You should be able to easily work that mismatch out...but if there is a mismatch at the bottom, that may be another issue.
DavidApp
Get all the bolts in and tight while you are at this stage in the painting process. I did not do that and had to push and shove the finished painted panels. More work at your stage would probable have helped a lot.
David.
sp53
I usually take a couple 12 inch or so ¼ diameter punches and go in from the back side or through the headlight hole or grill and work the high spot out by sticking the punch in through 2 holes and prying them where I want them then put a bolt in a close by hole. I left the bolts out at that stage that went into the tub itself and worked the fender and apron by themselves and let the nose of the car float on the tub.
steve
charleyf
I agree with most of the above comments. It is not a mismatch. Mine was this far off , I started from the top and worked my way down. I Also removed all of the fenders to paint he car. So putting it back together again will be necessary. I intend to have a helper to "gently" push it into the proper alignment once it is painted.
DavidApp
When I thought I was going to have to remove the apron again I had considered drilling some 1/4"alignment holes through the wing apron flange to help me get it back in line.
I ended up taking the gearbox out through the cockpit so I did not have to remove the apron.
David
71TR6
71TR6
After quite a bit of loosening/adjusting, I was able to match the wing to the apron a little closer. Still a little less than an 1/8” mismatch but it is better. It might be down to where the fender bead may help hide it.
Thanks for everyone’s guidance on this!
Ron
M TR2/3/3A Loose wing beading TR3A Triumph 4
M TR2/3/3A TR3A Wind Wing Hardware Triumph 10
Tinkerman TR2/3/3A TR3A Rear Wing Clamp Installation Triumph 14
M TR2/3/3A TR3A Wing beading Triumph 7
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Hamish Racing General TR TR3a and TR7V8 Shelsley Walsh Hill climb action Triumph 0
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
