Windshield Wiper Mods and Upgrades
twas_brillig
Having just started driving our BJ7 (roll up windows)after decades of storage, I'm wondering about some operating items: the wipers aren't great. Pressure holding the blades to the glass seems poor; speed isn't the best; etc.
Has anyone modded theirs to have two speeds or variable speed? suggestions as to sources for better rubber blades and better arms?
Thanks,
Doug
Rain-X. Then you don't need the wipers.
I tried (on an extra set of arms)to bend the metal leaf spring behind the blades on the driver side (left hand drive). All it did was cause some lift in the center when the blades were directly in front and not much help at the sides. A two stage switch or variable speed switch, in my opinion, would not make it any faster but give you a slower option as the limit is the total the motor will put out. Good luck with this.
TH
Johnny
Well Doug you've forgotten the first rule in BMC weather protection: "All weather protection, be it convertible top or windows, or wipers are only meant to keep water off the car when parked, not while driving". Now it all makes sense right?
:jester:
T
twas_brillig
You mean they're expected to keep things dry when the vehicle is parked? On the street? Exposed to the elements? Or only when parked, under a roof, with heat, and a dehumidifier? I always was suspicious that the sidscreens/tonneaus/tops were only provided for their aesthetic appeal...
Doug
T
twas_brillig
Well, some 13 years later, I'm back with the same question! I think we've got adequate tension in the arm but the wipers don't particularly wipe. Ten pounds sterling each from AH Spares; I called a local parts place and asked about replacement rubber only, but they haven't been able to get any for more than two years. Amazon et al sell wiper blades, but has anyone successfully ordered rubbers on line, and who from etc.? And has anyone come up with an after market blade assembly that could be attached to the original arms (which are 17 pounds sterling). Thanks, Doug
gonzo
It may be possible to make your own custom blades / replacement rubber from a modern car. Just cut it to size. Toyota's replacement rubber use the same design type utilizing two metal stays providing tension and retention. They're inexpensive and worth a try...
gonzo
For those interested the 2021 Toyota (Highlander) wiper replacement insert Part No.s are 85214-0E130 and 85214-E151 one of these is 22 inches and sufficient to refill both wipers for our AH 3000 measuring in at a humble 10 inches.
John Turney
I just bought a pair from Moss. 164-977 is the rubber and the metal spring on the back. Oops, mine are 9", not 10".
I once lost a wiper on my BJ8 on a road trip years ago. I managed to find a suitable replacement at a Napa store, except it was black (blade+frame only). A while later, I got a 'hot tip' from someone that RockAuto had a closeout on a Japanese-made wiper that was a perfect fit, and I bought, IIRC, a dozen at about a buck apiece (I think shipping cost more than the wipers).
Rob Glasgow
If I remember correctly, i bought a set of blades for a VW Beetle and took the rubber part out and inserted them in my BT7
holders.
R TR2/3/3A Windshield Wiper System Triumph 2
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
D TR5/TR250 Windshield wiper motor Triumph 9
R grease for windshield wiper motor- BJ7 Austin Healey 4
P Bugeye Windshield Wiper Motor Spridgets 3
C windshield wiper stupid question Spridgets 7
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
P windshield wiper motor Triumph 14
B Windshield wiper arm MG 3
TraceZ how to remove windshield wiper motor. Spridgets 7
Roger Elan Windshield Wiper Lotus 2
I TR6 help with TR6 windshield wiper arm removal Triumph 6
B TR2/3/3A TR3 Windshield Wiper Tubing Triumph 5
NutmegCT Windshield wiper scratch removal? Restoration & Tools 14
I Windshield wiper help please. Spridgets 1
G Windshield wiper blades MG 2
G Windshield wiper motor MG 16
KVH TR4/4A TR4 Windshield Wiper Motor Issue Triumph 8
A TR2/3/3A TR-3A windshield wiper assembly Triumph 2
Michael Oritt Variable Speed Windshield Wiper Austin Healey 4
Tinkerman Lucas windshield wiper motor DR-2 rebuild? Triumph 9
Ohiobugeye Bugeye Windshield Wiper Installation OUCH !!!! Spridgets 3
R BJ-7 windshield wiper motor wiring problems Austin Healey 3
C Are there spacers for the windshield wiper posts? Spridgets 3
G TR2/3/3A TR3A Windshield wiper motor...any help? Triumph 2
58Custom Windshield wiper questions Spridgets 1
M Windshield Wiper Alternatives Spridgets 5
M 90 XJS Windshield Wiper Won't Shut Off Jaguar 5
T Windshield Wiper Gearbox Grease Austin Healey 2
RSMTR8 Windshield Wiper Scratch Removal? Triumph 5
V Windshield Wiper Motor Jaguar 3
X Windshield wiper problems Spridgets 3
V Windshield wiper motor Jaguar 8
kcbugeye1275 Windshield wiper motor Spridgets 7
C Windshield Wiper Upgrade - AH 3000 Austin Healey 4
K T-Series Windshield wiper path scratch removal question MG 17
P Windshield wiper drive post rubber grommets Austin Healey 1
W windshield wiper tech on 74 XJ6L Jaguar 1
J windshield wiper motor Triumph 1
W Windshield / Windscreen Wiper Motor Austin Healey 1
A windshield wiper motor MG 5
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
D TR2/3/3A Windshield glass doesn't fit Triumph 6
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
D TR2/3/3A Windshield assembly question Triumph 6
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
