jjbunn
I couldn't understand why, when I tested my washer fluid pump on the bench it worked fine, and yet when I installed it in Harold it pumped no water at all.
Now I have just been browsing through the Owner's Guide part of the Bentley manual, which has a diagram of the connections between the pump and the water bottle. And it is the *other way around* to how it's connected in Harold! In other words, the pipe from the washer bottle in Harold is attached to the frontmost nozzle on the pump, whereas in the Bentley manual it shows it connected to the rearmost nozzle!
Which of the pump's nozzles is to be connected to the washer bottle: the front or the rear?
