TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3?
Joel Lester
Hey guys,
I've continuing my frame up restoration on my "58 TR3 and am replacing seals on the differential. There are signs that the pinion seal was leaking and I was hoping to use a speedi-sleeve to solve my leaky problem once and for all. The flange shaft doesn't seem to have a wear ridge or any pitting but since I have the whole differential out and sitting there... now is a good time to get it done. I live in Canada so shipping from Moss motors gouges me every time - I have a local NAPA parts supplier that has them - I just need to know what size to get for the pinion shaft. Anyone have the SKF part number?
Thanks a bunch!
Joel
Graham H
If the sealing surface looks undamaged but there is evidence of oil leakage it is most likely coming from the splines. I would just clean up the flange sealing surface with some emery tape and use some aviation gasket cement on the splines and the large flat washer and it should be good to go.
Graham
TR4nut
Pinion repair sleeve is 99149 if you do go that route.
sp53
I have limited experience with speedy sleeves. Some years back I tried one for the front seal and everything went fine until I tried getting the shaft back into the seal; it would not fit because the sleeve made the flange too large.
Perhaps if I would have gotten a larger seal with a bigger center hole things may have worked. after it did not work I instead cleaned the flange with very light emery cloth and put some JB into the small pits and used the emery cloth to smooth the shaft.
Anyways Napa is usually pretty good about helping, so I would suggest taking in the seal and flange and see if they can set you up.
Steve
Joel Lester
Joel Lester
Thanks again guys! I looked at the shaft again last night and I could feel the smallest wear groove where the old seal was. So I’m going to try and get the Speedi-sleeve 99149. I will also seal the flange surface too. No leaks is the goal!
Joel
sp53
Our buddy Randall suggested that the seal and grove will probably not be in the same place the second time. kinda like stepping into a river in the same place twice. Also check that the PO did not put a scare in the case if the old seal was replaced. Those factory seal were leather and high quality and can really put up a fight coming out, so be very careful of the case. Perhaps put some of your favorite sealer around the outside of the seal when you knock it in.
steve
Joel Lester
Joel Lester
Took the seals out last night... and you are right. They were leather. Didn't have much trouble getting them out though. The proper tool was handy. A seal puller with a slide hammer. Worked like a charm. When examining the axles for groove wear - one side had a fairly nasty groove. Also, the new seals I got from Moss are thinner and I bet you are right in that they would wear in a different spot. However I still feel as though getting the speedi-sleeves in will be a nice insurance measure. Picking those up on the way home from work tonight :bananawave:
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
CARSINC Spark plug thread size Spridgets 2
R Vixen 2500 Lug Nut Size? TVR 5
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Bayless What size battery for my '67 Sprite? Spridgets 5
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
S TR2/3/3A Vacuum Advance Union Size Triumph 1
T Radiator Hose Size Austin Healey 2
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B Exhaust Pipe Size Austin Healey 26
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
Healey Nut TR6 Headlight size Triumph 58
MadRiver TR6 Emissions Hose/Tubing Size? Triumph 2
JPSmit Not quite an LBC - but the size might be close :) Restoration & Tools 3
B TR4/4A Oil Drain plug size Triumph 14
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
69MGC MGC What size tires will fit nicely MG 2
M TR5/TR250 Compatible Modern Tire Size Triumph 5
J Nut size for BJ8 center console trim piece Austin Healey 8
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
D TR4/4A SU HS6 throttle spindle size Triumph 20
C Size or matching screw on cap for Trafalgar bottle? Austin Healey 0
Bayless What size fuel line for '67 Sprite? Spridgets 2
S Bugeye Radiator Tank Plug Size? Spridgets 24
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
K Abington Allocation Plate size? Austin Healey 1
R TR4/4A Door mirror base size Triumph 2
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
S TR2/3/3A Pixel primmer size Triumph 18
F TR2/3/3A Spare Tire Size Triumph 11
C Size of axle bearing nut Austin Healey 11
GeorgeC Steering wheel nut size? Spridgets 3
ckeithjordan TR2/3/3A Trim Hole Size Triumph 3
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
KVH TR4/4A Belt Size for TR4A Triumph 4
P TR2/3/3A Recomended enclosed car hauler size? Triumph 8
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
55modified Radiator sensor thread type size needed for bn1 Austin Healey 12
jfarris For Sale New TR3 Rod Bearings Big End Std Size Triumph Classifieds 0
George Zeck Wheel Stud Size? Spridgets 10
Jim_Gruber Size Matters Spridgets 3
2billydavies TR2/3/3A belt size for TR3a? Triumph 13
Rut TR4/4A steering shaft/nut thread size Triumph 5
S T-Series screw size MG 0
