What are HD6 carbs worth?
Jerry
I just rebuilt the HD6 carbs with Burlen rebuild kits. They have new shafts, seals and everything else needed in the kit. Someone on the forum was interested in buying them but I don't have an idea what they are worth. Do any of you wish to offer an opinion? The rebuild kits cost $165.
Thanks
Jerry
steveg TR6 HD6 carbs on TR6? Triumph 16
jfarris For Sale Air Horns for SU HD6 Carbs Triumph Classifieds 4
F How important is getting the float height correct on SU HD6 carbs? Austin Healey 3
F Adivce on how to center jets of SU HD6 carbs Austin Healey 3
Lin K&N Air Filters for SU HD6 carbs Austin Healey 14
B Adjusting SU-HD6 Carbs Austin Healey 2
N HD6 / 8 carbs. Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
Lin HD6 1-1/2" SU Front [L/H] Float Chamber Austin Healey 1
F How to restore screws, springs and fixings on SU HD6 Carburetors? Austin Healey 7
J SU HD6 - Slow Idle Screw Austin Healey 13
C HD6 Carburetor Spacer Blocks Austin Healey 4
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
B SU-HD6 Gas Leaks Austin Healey 6
britndablood HD6 jet diaphragm only lasted 8 months Austin Healey 7
BOBBYR HD6 CARBURATORS????? Austin Healey 3
I Setting up / Tuning an HD6 Carb Austin Healey 3
red57 Fitting 3 HD6 to 6 cy Healey Austin Healey 10
DerekJ Triple 3/4" SU's HD6 Austin Healey 12
G HD6 Question - on TR6 Austin Healey 4
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
jfarris For Sale SU H6 Carbs AUC 878 - SOLD Triumph Classifieds 0
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
poolboy For Sale REBUILT Carbs for TR6 Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
steveg Healeys with Mikuni Carbs Austin Healey 13
P TR2/3/3A TR3B SU carbs Triumph 10
KVH General Tech Carbs Flooding While Car Sits Triumph 55
K 1966 Austin 1100 carbs? British Motor Corp 1
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
steveg HS vs HD series carbs Austin Healey 2
P For Sale v12 carbs Jaguar Classifieds 0
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
K For Sale Two Rebuilt TR3 AUC 878 SU Carbs Triumph Classifieds 3
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
Michael Oritt Leak from carbs Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
D Starting After Carbs Rebuilt Austin Healey 30
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
69MGC MGB Wanted: Pair of 67 or earlier Carbs MG 2
69MGC 65 to 67 carbs wanted MG Classifieds 4
K 66 Austin 1100 Carbs British Motor Corp 1
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
M Cooper's Air Filter on H1 Carbs Spridgets 5
