HD6 / 8 carbs.
NIB
Is there some simple way to identify identify if you got HD6 or HD8 carbs mounted on the car, without taking them off and measuring the diameter.
On the top of the square flange bolted to the inlet manifold D2-6 is stamped, i guess it means HD6? But on the float chambers it says AUD124, which is HD8.
Would be nice to know before i order parts. The car is a 1966 BJ8 so they should be HD8, but the D2-6 confuses me.
Greetings
Niels
Denmark
John_Progess
Niels,
You probably do have HD8 carbs unless you have some reason to believe that someone has replaced the originals. My 64 BJ8 carbs have A76 stamped on the front carb flange and A86 stamped on the rear carb flange. I have no idea what that number means. My carbs also have the AUD124 on the float bowls. Have a good day!
John
N
NIB
When i bought the car from the dealer, I was informed the engine had been totally rebuilt two years ago because the previous owner had run it with no oil pressure. The previous owner had the dealer do the rebuild, and since he was also short of money, he later sold the car to the dealer.
I bought the car form that dealer.
I just got a workshop manual and was looking at all the numbers, and discovered the engine block is a 29D and nok a 29K as its supposed to be. I havent heard from the dealer yet, if he just replaced the block because it was too damaged or how he did the repairs, but im planning on checking all numbers on the parts around the engine to see whats original BJ8 and whats not.
Niels
Johnny
Don't the HD6 carbs have brass tops and the HD8 black plastic?
The portion of the dashpot where the dampener screws in is also much shorter on the HD8 than the HD6.
To me, that's the most obvious visual clue.
Unfortunately, I'm severly lacking in pictures of SU carbs, but these are a glimpse of HD8s:
Don't go by the brass cap. Many replace the black plastic with the brass cause the black plastic ones break easily and the brass looks cool when you polish it.
TH
TimK
As usual, Randy has great attention to detail. Here are my HD6 carbs on my 29D engine block and the tops are definitely taller than the HD8.
terp83
Niels-
Each flange on my pair of HD8's has a "B3 6" stamp. I have owned these SU's and the BJ8 since 1973 and am sure that the carbs are HD8's.
Jerry
SideShifter Tri-Carb
Didn't the Jaguar HD8s have a different dashpot neck. I seem to recall people sawing them down and rethreading to make a proper dashpot cover for a Healey.
N
NIB
I have the short tops, so its HD8.
Had a talk with the dealer, he had sent the engine to an engine workshop to be repaired. He knew the engine block had been replaced because it was too damaged, but he always believed it was the correct type that what used. Bit annoying to know that now, I have to have a look at the parts to see what 29D and whats 29K, is there a list somewhere where you can see the difference?
Niels
BobFrisby
Member
You only have to remove an air cleaner to measure the throat diameter, and that of course will tell you for sure what you have. 1 3/4"=HD6 and 2"=HD8.
Niels
About the only real difference, as far as replacements go, is that the dipstick tube is slightly different, and the dipstick itself could possibly be a different part number.
It's really not such a big deal.
I'm guessing that you haven't pulled the filters off a BJ8 lately? PITA!
By far and away, I would rather be able to tell at a glance :wink:
steveg TR6 HD6 carbs on TR6? Triumph 16
jfarris For Sale Air Horns for SU HD6 Carbs Triumph Classifieds 4
F How important is getting the float height correct on SU HD6 carbs? Austin Healey 3
F Adivce on how to center jets of SU HD6 carbs Austin Healey 3
Lin K&N Air Filters for SU HD6 carbs Austin Healey 14
B Adjusting SU-HD6 Carbs Austin Healey 2
J What are HD6 carbs worth? Austin Healey 0
S Leaking HD6 Rear Carb Austin Healey 10
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
Lin HD6 1-1/2" SU Front [L/H] Float Chamber Austin Healey 1
F How to restore screws, springs and fixings on SU HD6 Carburetors? Austin Healey 7
J SU HD6 - Slow Idle Screw Austin Healey 13
C HD6 Carburetor Spacer Blocks Austin Healey 4
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
B SU-HD6 Gas Leaks Austin Healey 6
britndablood HD6 jet diaphragm only lasted 8 months Austin Healey 7
BOBBYR HD6 CARBURATORS????? Austin Healey 3
I Setting up / Tuning an HD6 Carb Austin Healey 3
red57 Fitting 3 HD6 to 6 cy Healey Austin Healey 10
DerekJ Triple 3/4" SU's HD6 Austin Healey 12
G HD6 Question - on TR6 Austin Healey 4
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
jfarris For Sale SU H6 Carbs AUC 878 - SOLD Triumph Classifieds 0
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
poolboy For Sale REBUILT Carbs for TR6 Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
steveg Healeys with Mikuni Carbs Austin Healey 13
P TR2/3/3A TR3B SU carbs Triumph 10
KVH General Tech Carbs Flooding While Car Sits Triumph 55
K 1966 Austin 1100 carbs? British Motor Corp 1
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
steveg HS vs HD series carbs Austin Healey 2
P For Sale v12 carbs Jaguar Classifieds 0
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
K For Sale Two Rebuilt TR3 AUC 878 SU Carbs Triumph Classifieds 3
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
Michael Oritt Leak from carbs Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
D Starting After Carbs Rebuilt Austin Healey 30
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
69MGC MGB Wanted: Pair of 67 or earlier Carbs MG 2
69MGC 65 to 67 carbs wanted MG Classifieds 4
K 66 Austin 1100 Carbs British Motor Corp 1
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
M Cooper's Air Filter on H1 Carbs Spridgets 5
