Weight of BJ7 Transmission/Overdrive
twas_brillig
Has anyone got a shop manual to advise as to the above, as I know the figure is in there but I can't find my reprint.
We changed to a Toyota 5 speed some years ago, and have kept the original transmission and overdrive. I'm going to have to move the tranny et al to a different storage location, and would appreciate knowing what the original manual advised as to its weight - can two old guys move it in to the back of the pickup, or should I get an engine hoist? Thanks, Doug
BoyRacer
My recollection is that it weighs around 120 lbs. I don't think you will find the weight listed in any manual.
T
twas_brillig
The weight is shown in the original shop manual and its reprints, and my memory is the same as yours (about 120 pounds) but surely to goodness someone has a manual and could advise (?). Doug
T
twas_brillig
Thanks guys. We can skip the engine hoist. Now, if I was only as young as an old geezer....
For reference, the side shifter, compared to a (stronger...) MGC xmsn. I recorded these weights when I reverted back to the s/s trans from the MGC box I'd fitted back in the 80s... > Healey-at-home / gearbox work / transmission installation | spcarsplus.com photo gallery <
s/shift (complete w/bellhousing, shift lever & overdrive: 116.6 Lbs
MGC: 85.8 Lbs
While I'm at it, a couple of flywheel weights.
BJ8: 26.8 Lbs
"shaved" (to work w/MGC xmsn): 20.2 Lbs
(Hi Basil, got your note ;) )
gonzo
Center Shift Transmission is more unwieldy than heavy; I managed R&Rs on my own many times but an extra pair of hands is always helpful. Best advice, save back and get some help with that thing.
T
twas_brillig
Yay! Found my shop manual reprint!
And - at the end of 'General Data' - it provides the following "Weights of Components"
Engine: 611 pounds; Gearbox, standard: 79.5 pounds; Gearbox, with overdrive: 117 pounds; Rear axle: 166 pounds.
We'll try loading it on Monday; wife will come lend a hand as well. Back protection will be paramount.
Thanks to all!. Doug
bob hughes
It is a few years ago now, but this old fogey managed it on his own, getting it out of the car, including the clutch housing and overdrive and with the use of a low level 4 wheeled trolley to move it into the garage annex. I removed the clutch housing and lifted the rest into the boot ( trunk) of my car to take it around to a Garage mechanic.
The upshot is that two should be able to move it without contracting a hernia. 😖
:cheers:
Michael Oritt 100 Flywheel Weight Austin Healey 16
T TR2/3/3A Body Tub Weight Triumph 8
X Technical specifications including the maximum technical weight TVR 8
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
H MGA MGA engine weight? MG 3
TRMark TR4/4A TR4 Weight Loss Program Triumph 6
banjojambo TR2/3/3A TR3A adding weight to improve handling Triumph 5
R Engine component weight reduction Austin Healey 53
BoyRacer weight of bare Healey chassis Austin Healey 8
T TR2/3/3A TR-4 Tail shaft counter weight Triumph 4
kennypinkerton MGB Body shell weight? MG 3
kennypinkerton MGB Rubber bumper weight surprise.. MG 4
BOBBYR Frame weight Austin Healey 14
T Weight of a Bug-Eye bodytub: approx 220 pounds Spridgets 10
Willie_P TR4/4A Weight Weenies: Tr4 relo of battery to boot...good idea? Triumph 6
glemon General TR Weight Loss Program Triumph 9
GeorgeC Hardtop weight? Spridgets 6
Griz Engine weight Austin Healey 13
2billydavies TR2/3/3A engine fan assembly on TR3a: balance weight question Triumph 3
R weight of BJ8 Frame with inner body panels Austin Healey 1
P 1275 Weight?? Spridgets 3
D Engine weight Triumph 4
O TR2/3/3A TR3 Overdrive Weight? Triumph 6
5 TR2/3/3A TR3 bare shell weight Triumph 9
G RB weight sans driveline and bumpers? Spridgets 5
T Weight difference beween steel and wire rims Triumph 11
S Weight of Bugeye unibody Spridgets 2
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
M 3.0 iron weight difference Austin Healey 7
J Another pic of the E-Type light weight Jaguar 0
G Spitfire Weight diff b/w Spit 4 and 6? Triumph 3
A Rear end weight? Austin Healey 7
J TR2/3/3A TR3 tub weight? Triumph 16
B Engine Oil Type and Weight? Austin Healey 8
Frankenhealey Aluminium everything - weight saving? Austin Healey 3
hilsideser Spitfire Spitfire frame weight? Triumph 6
B Rear Clip weight Triumph 2
Ken40 MGB-GT MGB/GT body shell weight MG 3
B Race spridget weight jacking Racing 8
aeronca65t Corner weight setup Racing 3
K Curb weight Triumph 4
BionicHealey Chassis Weight Austin Healey 13
PatGalvin TR2/3/3A TR3 Flywheel Weight Triumph 9
B piston/rod assembly weight Austin Healey 0
B Need for piston/ rod assembly weight Austin Healey 4
vette Engine Weight Austin Healey 19
healeyboz flywheel weight Spridgets 2
T Is the Patton aluminum crank hub enough weight? Triumph 21
rick_ingram MGC Weight of MGC MG 21
VelodromeRacer Weight reduction battery? Racing 6
