weber vacumn line connection for BMW
eejay56
My sons beemer has two vacuum lines to the distributor, one is connected under the choke unit on the Weber DGV. The other is missing. Where should it connect?
eejay56
eejay56
It is a 79 320i converted to a Weber DGV carb. The dizzy has vacuum advance and vacuum retard lines. Currently only one is hooked up.
SteveL
Is it a Bosch dizzy?? The port on the back side of the
vacuum can should hook to a manifold source, the front
side should hook to the port near the idle enrichment
screw...
SteveL
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
H Triple Weber 45's Tipp? Austin Healey 2
JFS TR2/3/3A Weber Air Filters Triumph 7
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
toysrrus TR6 Weber DCO45 cost? Triumph 6
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
bugedd Weber intake manifold Spridgets 4
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
T Weber for a 1275 cc engine? Spridgets 6
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
drooartz Leaning out/tuning a Weber on a 1275 Spridgets 20
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
krswen Comparing Weber kits .... advice sought Jaguar 4
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
DanLewis Side draft Weber and smell of gasoline? Spridgets 3
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
W Weber/stromberg air cleaners Jaguar 3
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
B Weber DGV Spridgets 2
TomChar Weber MCHH carbs Triumph 23
A TR6 Triumph TR6 Triple Weber carbs Triumph 9
Pythias Weber DGAV questions Spridgets 8
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
Coyote1 TR6 Weber 45 MCHH conversion for TR6 Triumph 15
