Tudor Washer Blue Color Match Needed
hmsevans
I am looking for a Tudor Blue color match to Paint my Bottle Bracket for a 1966 PH III 3000.
I have the Orig. bottle ,but its a bit faded to match.
Does anybody have a Paint code and Source?
Thanks
Mark Evans
PAUL161
For $2.60, you can get a new bottle sticker from Moss and then have it scaned by a paint store. PJ
hmsevans, is this a factory color? ive got the "guide to historic colors" but it doesnt show a " tudor blue", ive looked till i was blue inna face! :savewave:
T Tudor Washer Bottle Holder Austin Healey 1
W Tudor windscreen washer bottles Spridgets 0
theleisure TUDOR Washer Bottle Look-a-Like Oil Catch Can Spridgets 3
B Tudor washer bottle Austin Healey 9
TulsaFred Tudor washer pump- Bugeye Spridgets 10
apbos Tudor Washer Bottle Spridgets 10
W Bugeye Tudor Wash Bottle Decal Spridgets 0
K TR2/3/3A Picture of the Zinc washer. Triumph 3
W Glass Washer Bottle Lids Austin Healey 0
J Thackery Washer Austin Healey 3
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
J TR4/4A Washer bottle bracket screws Triumph 3
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
M TR6 Wiper washer knob Triumph 5
steveg TR6 Late Wiper/Washer Switch - What Happened? Triumph 3
B TR4/4A Thrust washer issue Triumph 11
4tecdog Fibreglass bonnet washer fittings Spridgets 5
M TR6 Clutch Master Rebuild: That Crazy Wavy Washer Triumph 1
R Windshield Washer Pump Repair Austin Healey 9
K Diameter of Washer Bottle Hole in Parcel Tray Austin Healey 4
M TR2/3/3A Standard Engine Trust Washer Thickness Triumph 18
B TR6 Winshield washer bottle location Triumph 2
D Wanted washer for hood catch Triumph Classifieds 2
K Windscreen Washer Question Austin Healey 26
Tim Tucker TR6 Trailing Arm NYLATRON bushing-washer gap questions Triumph 4
NutmegCT T-Series Carb banjo washer leaks? MG 9
G TR4/4A Windshield Washer Tubing Routing Triumph 1
B Windscreen washer pump upgrade Austin Healey 10
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
D TR4/4A square engine mount washer necessary? Triumph 6
Got_All_4 TR2/3/3A Push switch for washer fluid pump Triumph 4
K Thrust washer Austin Healey 4
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
K Starter Drive Washer? Austin Healey 1
busybrit Healey 3000 distributor drive gear spacer washer, end float! Austin Healey 2
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
B Two Longbridge BN4 Questions - Indicator Light and Washer System Austin Healey 8
bighealeysource Fibre washer on O/D drain plug doesn't fit well Austin Healey 7
longbridgehealey Longbridge built 100-6 dual washer nozzle Austin Healey 6
Rut MGB Oil pressure gauge leather washer MG 13
K TR2/3/3A Rear spring again....front pin "D" washer? Triumph 7
T Trafalgar Washer Bottle lid decals Austin Healey 4
Jim_Stevens TR2/3/3A A-type OD operating valve copper washer Triumph 3
M TR2/3/3A TR3A gas cap fiber washer Triumph 6
I TR6 Windshield washer jets...placement and installation Triumph 1
Jim_Gruber Repairing BE Washer Pump Spridgets 5
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
