TR6 TR6 Shock Conversion Kits
Colin_D
Hello all,
I am planning on replacing the rear shocks in my TR6 with a tube shock conversion kit. There are 3 or 4 different designs that I know of, has anyone had good and or bad luck with any of the kits?
Colin
71tr
You should get quite a few opinions on this topic. I'm making a similar decision and chose the bracket from Moss Motors that attaches to the lever shock mounting bolts. I liked the closed top design as compared to some of the other offerings.
G
British Parts North West makes the most popular conversion, the one-piece unit that comes with the KYB shock. I converted to a Spax shock for better ride and control.
WidespreadPanic
[ QUOTE ]
[/ QUOTE ]
I got mine from BPNW and am very happy with the results. They also happen to have the best price for the KYB version. ($150)
linky
DougF
I will agree with the unit that bolts into the existing shock mount holes. Some may argue that you don't have as solid a base. If you are planning to race, the mounting into the body design may be better. But for a daily driver, bolt in, in my opinion, is the way to go.
If it ends up you want to go stock again, you haven't altered the body in any way.
swift6
Most racing organiztions won't allow you to change the shock mount locations for production class racing. Unless they have gotten a bit more lax on that.
Paul Slice
i went with the Blind moose conversion brackets https://www.blindmoosefab.com/rear_shock.htm along with Koni shocks, very happy with the conversion.
Paul
Paul Johnson
I used the kit from Victoria about 20,000 miles ago. Took less than an hour to install and has worked fine since.
ALLAN
Same as TR6BILL-- BPNW conversion with spax shock. The KYBs are usually too stiff for most. The BPNW conversion allows a little more room for tires and wheels than the other conversions, I run 7x15 with 225/60/15 with no problems. BPNW has the best price on Spax shocks, they might sell the kit with Spax instead of KYBs.
C
Colin_D
I got the kit from Moss motors as a Christmas present but with out the shocks, BPNW has the best prices for Spax but I don't know which shocks to order for the back. Does anyone know??
crj7driver
For those that have done a rear shock conversion, what is biggest benefit or difference. My suspension is all polyurithane and the springs are the "race" versions. The stock shocks are in good working order and so far I am very happy with how the car handles. But for $150 from BPNW I might be game.
G
FWIW, Richard Good still runs lever shocks on his hopped up TR6. That says something.
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
S TR6 TR6 shock links Triumph 10
S TR6 tr6 rear shock part number ??? Triumph 5
I TR6 TR6 front shock help Triumph 2
T TR6 TR6 Rear lever shock rebuild: Triumph 3
A TR6 TR6 Rear Tube Shock Conversions Triumph 13
V TR6 TR6 Tube Shock Size [front and rear] Triumph 9
M TR6 Help- TR6 rear shock mount cracked Triumph 3
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
