SpannerMan
Hi all,
I recently moved up to NJ, bringing my 71 TR6. Sooner or later it will need to go through inspection here. There's a safety inspection, and an idle emissions test.
Does anyone out there know what the idle emission specs for '71 in NJ are? The car idles well without more than the occasional miss, and the mixture looks good on the plugs. Is that likely to be sufficient??
I notice also that 'visible blue smoke' is a potential failure. Is a puff after it's been idling or sitting (some wear in the valve guides I think) usually a failure, or are they likely to let that go? I have also thought about adding some STP 'smoke treatment'. Does the stuff work, and is likely to have any bad effects? I am just thinking I'd be better off trying to pass first time than come back for a repeat where scrutiny might be even higher. I'm running Castrol GTX 20W50 by the way. Also, should I do the free state inspection, or pay a garage to do it?
Thanks a lot!! Wish me luck, Pete
