TR4/4A TR4 Door Restraint
TRMark
Bronze
Having owned the car for so long, I am my own worst DPO. Many years ago I trimmed this door restraint part. Can anyone give me the correct dimension?
TRMark
TRMark
Bronze
Thanks Tim. Did you measure overall length or from center of bolt holes to the end?
SCguy TR4/4A TRIUMPH TR2 TR4 DOOR RESTRAINT ASSEMBLY Triumph 1
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
Zitch For Sale TR4 - old door cards Triumph Classifieds 0
M TR4/4A TR4 door glass spacer wires. Triumph 1
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
M TR4/4A Where to buy replacement TR4 exterior door handles? Triumph 1
Tim Tucker TR4/4A TR4 Door Hardware Color Triumph 2
M TR4/4A Tr4 Tr4a door handles Triumph 2
H TR4/4A Tie Rod In Door - TR4 Triumph 5
TR4A_IRS TR4/4A TR4/6 Door Fitting Triumph 3
TR4nut TR4/4A Anyone have any spare TR4/4A door glass? Triumph 12
M TR6 tr4-tr6 door switches Triumph 3
J TR4/4A TR4 door checkstrap replacement. Triumph 9
71tr TR6 TR4 door handles on a TR6 Triumph 4
F TR4/4A TR4 Question: Door check strap pin Triumph 5
S TR4/4A TR4 Door Check Straps Triumph 4
A TR4/4A TR4 A wood glove box door question Triumph 0
toysrrus TR4/4A My TR4 got "CRUNCHED" Today!!!!! Need Door!!!!! Triumph 46
M TR4/4A TR4 Door compatability Triumph 3
M TR4/4A TR4 Door Seal channels Triumph 4
TR4 TR4/4A TR4 Door Fit ? Triumph 2
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 6
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
