I'm new to the forum, and midway through rebuilding my 1963 TR4. I've had the engine out, had the crank turned, replaced the crank bearings, rebuilt the head, put it back together, rebuilt the SU H6s, clutch/brake hyraulics, fuel pump...
I've got two challenges:
1. I have a slow coolant leak up past one of the head bolts next to the valve cover. The coolant appears to be coming up the threads of the head stud and the nut. What's causing it?
2. I've rebuilt the SU jets twice, and the right one still leaks fuel slowly. I've already checked the floats, replaced the check valve (with the Grose version), replaced the seals with o-rings, but it still leaks. What gives?
Thanks for any help.
