TR2/3/3A Tr3A Control Head
DavidChandler
I recently removed the 3 grub screws that help to secure the control head (trafficator)on my 61 TR3A. I thought reassembly would be a simple reverse process, but I'm having trouble getting the grub screws back into a working position. They were holding the trafficator before, but when I try to tighten them down now they seem to not catch on anything - one went all the way through and was rolling around inside.
Can anyone provide any info on what these screws are supposed to latch onto? I'm stumped.
Mickey Richaud
Hi, David -
Sorry, but I don't remember from the TR3 that I had. But wanted to welcome you to the BCF, and I'm sure someone will post an answer soon!
:cheers:
Mickey
Don Elliott
There is a round plate about 3" outside diameter on the rear of the complete assembly. Look carefully at the outer edge of this circular plate and you will notice it has an inverted "V" profile all around. The grub screws are pointed on the inner end and if you unscrew the grub screws quite a bit, you can push the whole assembly into place far enough. The point on the ends of the three grub screws will "catch" onto the inside of the inverted "V" and it should be secure.
DavidChandler
DavidChandler
Don -
Thanks for the info and the picture. After getting everything back together (correctly, I think), I now suspect that I may have a stator tube problem. The control head continues to turn with the wheel regardless of what I do with those screws.
Based on other posts about the stator tube I think I may need an appointment with the local LBC specialist for that nightmare.
Thanks again.
TR3driver
Great Pumpkin - R.I.P
The stator tube isn't that hard to deal with, you could probably do it yourself if you want to. The main hassle is removing the control head & it's harness. Once that is out of the way, you just loosen the nut on the steering box, fiddle a bit with the compression sleeve to get it off, and then pull the tube out through the steering wheel.
ekamm
I repaired mine with some brazing rod. Not too big of a deal. Of course after careful cleaning and lubrication of the control head. I put everything back correctly and the two pieces that should cancel the indicator lever wont extend far enough to fully center the lever. I'm not sure if they are worn down that far or the springs inside of them don't extend enough.
TR3driver
Sounds to me more like a problem with the long springs on the curved metal piece. They are what actually return the lever to center.
Or possibly the little roller isn't in place? Maybe turned the wrong way?
ekamm
Randall the two pieces where your thumb is in the picture don't come out far enough for the ring to hit them with enough force to kick the lever back to the center. Originally the problem appeared to be the ring. There was a grove worn in the ring. I filled it with JB and shaped it smooth with a dremel. It worked well at first but after a few days when the steering wheel came back it didn't contact the "pawls". It's as if they are worn on the ends.
TR3driver
So yours don't stick out as far as this?
ekamm
They did when I reassembled but with it on the car they don't appear to be working that way. I need to remove it and see if I can tell what's going on. If I understand correctly the hinged part of the piece is spring loaded and that should make it stick straight out. Maybe they just aren't returning to the straight position.
Don Elliott
Randall - With all respect Randall, I believe that the way the lower end of the "flippers" should be as in my photo.
DavidChandler
DavidChandler
OK, I've disconnected the 4 wires at the steering box and pulled the control head back out of the stator tube. Now I'm confused as to how the the control head fits back into the tube. Shouldn't there be some kind of spline or something to slide into the slot in the tube? Mine has nothing, and I think something may have sheared off and this is causing the control head to turn with the wheel.
I haven't been able to locate a picture which would confirm my suspicions. Mine is the adjustable steering column.
ekamm
If the tube is broke which is very likely you should be able to pull the upper of the tube up a little with the lower end staying stationary. There is a protrusion from the bottom of the tube extending from the control head. At least on mine the slot or spline is worn and there is some play in the head.
Now that I look at don's picture above I think maybe the stator tube slides inside the control head tube. In which case the spine would project inward on the control head portion.
TR3driver
You're quite right, Don, my bad. I just grabbed some bits from the bin for that photo, and put them together wrong.
Here's a shot that shows the dimples where the control head tube engages with the stator tube. This is a non-adjustable version, but the adjustable version is similar (it just has a much longer control head tube).
DavidChandler
DavidChandler
Thanks Eric.
It looks to me like the stator tube has to go inside as well, but I don't see anything on the control head tube that would function as a spline on either inside or outside. I'll try the stator tube movement test this evening.
F Wanted TR3A control head parts (trafficator) Triumph Classifieds 4
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
P TR2/3/3A TR3A Steering Control Head Harness Triumph 7
J TR2/3/3A TR3A control head question Triumph 4
tmc TR2/3/3A TR3A control head disassembly Triumph 4
ekamm TR2/3/3A TR3a horn/turn indicator control head Triumph 13
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
Tinkerman TR2/3/3A TR3A Control Hwead Wiring Triumph 4
Geo Hahn TR2/3/3A TR3A Control Box Triumph 6
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
