TR4/4A TR-4A FI street engine on the dyno at JB Racing.
nissanite
The focus was lots of torque. 150lbft from 3200 to 5000 and 143 hp at 5600. Going on the chassis today then of to the body shop to have the new black body lowered down. Only been 8 years but now showing progress
3 min vid shows start up, first run at 5000 with throttle at 6%,12,18,24 and 30%. Watch the header change color. next runs are power sweeps to 5500 & then 6000.
Very exciting (for me)
https://www.youtube.com/watch?v=a8h5o3QVPSI&list=FLEAUFEk4GZv2_mUyqunPqoQ&feature=mh_lolz
V
vagt6
Nice, big numbers for a street engine (I assume it's not a race car).
Please give us the build info on the engine: what's in there? And while we're at it, what about the suspension, etc?
Congrats, you're gonna love driving that TR. :yesnod:
Monkeywrench
Great street engine numbers. Square power figures are always nice! Sounds like you did your homework.
I too am interested in details.
nissanite
nissanite
65 second owner TR4A IRS
ratco frame - Goodparts diff & cv axles, hubs, front sway bar, coil over aluminum shocks, Porsche Boxter Ft brakes with stoptech rotors and aluminum hubs.Datsun 280zx custom rear disc brakes. Panasport with Bridgestone Turanza with Serenity. All steel parts have been nickel plated. Aluminum anodized.
engine - JB Racing built this with my his and my parts. 91mm custom made liners, Prepped crank, Revington Sprint cam, Kinsler one off intake with Haltech injection. Pauter rods Wisco pistons, goodparts roller rocker with stainless valve train form cambridge motorsports. ported polished. Custom one of a kind rear oil seal. lightend flywheel with custom damper pulley. 100 amp alternator. stainless header. building mandrel bent 2.25 stailess exhaust with Vibrant stainless twin rea mufflers & single resonator. Was talked out of being novel by cancelling the cat converter plan. ( attempt at being green )
rebuilt trans with O-drive
Body is at Freds Healey revival being painted black. should have body back on frame by March.
I know --- PICS
hondo402000
DO you have the print out on AF ratio, usually when the headers start glowing red you are running lean
Hondo
nissanite
nissanite
The air fuel ratio never went leaner than 13.3.
The engine was set at 5000 and the load was increased from 6% in 6% increases to 30%. That is when the pipes started glowing.
Chris Ludwig from Ludwig Motorsports is a Haltech dealer. He performed remote tuning from Indy to the shop near Orlando. It was amazing.
hermanmaire
Why did they talk you out of the Cat? I plan to install a sports cat mainly to kill the exhaust stink that I cannot stand.
JerryVV
I hope you can keep a crank together, racers go to the Moldex crank for revs much over 5000 which you'll be temped to do on a frequent basis............I know I would!
Monkeywrench
Stock crank should be okay if prepped. I think most racers on a stock crank are shifting at 6000rpm. Billets will go well over 7000rpm.
TRMark
Bronze
Just curious. What is difference/advantage/disadvantage of getting the horsepower this way as opposed to installing a supercharger?
Monkeywrench
Advantages:
Better throttle response
Less parts (potentially more reliable)
Bling factor
Disadvantages:
More expensive
Have to do your homework before you start buying parts
The why:
Why not? No one has a build like this, and superchargers aren't all that uncommon.
JeffS
I'm not sure I'd trust AFR numbers if they read 13.3 and the headers were glowing red. Its either a bad sniffer or a vacuum leak that's just not registering due to the location of the O2 sensor. Red headers are a serious reason to shut down and investigate!!!
Bremer
Very nice. Would you mind sharing details about your big bore liners, such as where you got them made and what needed to be done to the block to make them fit? Photos would be nice, too!
martx-5
It changed color <span style="font-style: italic">slightly</span>, but it never glowed red.
BTW, beautiful job on that engine. I'd like to hear more about the FI system.
Basil Across the Street Spotted 2
N For Sale 1964 Triumph TR4 street racer Triumph Classifieds 0
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
K TR2/3/3A Street cam again and Valve gap? Triumph 6
K TR2/3/3A Mild street cam and Idle? Triumph 13
Gliderman8 Falcon on street in Boston Spotted 11
Boink It's probably noisy on the street... Rover / Land Rover 0
BoyRacer Best street tires for early 3000? Austin Healey 21
S Best air cleaners/ filters for street Spridgets 8
H best street pads Austin Healey 6
G More low end and milage street 1500 Spridgets 11
B TR2/3/3A Street Roll Bar for TR3 Triumph 12
Russ Austin Ballet in the street, what a treat! Triumph 7
aeronca65t Street Legal! Other Cars 8
Jer Google Street View Spridgets 7
M 1275 street peformer, any hot rodders Spridgets 21
TR3driver TR4/4A New "hot" street cam for TR2-4A Triumph 8
1 07 Triumph Daytona 675 converted to Street Triple British Motorbikes 5
L Street Tire size for 60 spoke wheels Austin Healey 15
Team_Sprite A happy little street car pops up again Spridgets 5
aeronca65t Street Racing-Poland Racing 2
Jayrz Auto-X/ Vintage race/ spirited street ride height? Spridgets 14
kcbugeye1275 Street bugeyes on Ebay Spridgets 3
K TR2/3/3A TR3...Mild street cam....valve gap? Triumph 8
T Crypt Car dies in street Triumph 17
G Street tires for the Midget Spridgets 17
D Racing equipment helpful on street cars? Racing 10
S TR2/3/3A TR3 on the street for the first time in 10 years Triumph 9
DonPete3 Street Legal? Spridgets 2
Simon TR4a MGB MGB on my street MG 12
M TR4/4A Ebay TR4 spotted by chance on the street! Triumph 0
aeronca65t Rare Costin street coupe Other British Cars 5
Y Street names Sunbeam (Rootes) 2
C Reasonable power out of a good street B motor? MG 15
S Why is this car not street legal ? Lotus 3
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
