TR 2/3/4 aluminum sump gasket
newmexTR3
Hey guys,
Anyone here have an an aluminum oil pan? Any of those people have one that doesn't have a leaky gasket?
I've never been able to get the stock gasket to work well with my pan. Even after thread repair on some stripped threads in the block, I can't get a good seal.
I think part of the problem is that the stock cork gasket is much skinnier than the lip for the aluminum one. The aluminum pan also has a much thicker lip.
Ideally I'd like to get a silicon one, but no one is making them as far as I know. I spoke to Justin https://www.jmwagnersales.com, who makes the custom tr4/6 silicon valve covers, but it's really not worth it to him to fabricate.
Anyone have any suggestions for a home-made solution or tips for getting the cork gasket to not leak?
Cheers,
Gavin
TR4
Could you apply Permatex or a similar liquid gasket material to the cork to help seal it?
newmexTR3
newmexTR3
I always use a bead of the Permatex black, although only on the gasket>pan surface. Maybe I should put it on both sides.
Good, obvious idea. thanks!
mallard
I just got some Permatex Anaerobic Gasket Maker (#51813) for my engine rebuild. I got two tubes from a friend that said the product is very hard to find, but is a great sealant for Aluminum and Cast iron. I've never used the product before but was told you will not have any leaks with the product. It says it will fill gaps up to .050". I will see.
Geo Hahn
Sheet cork is pretty easy to work with if you want to make a gasket that matches the width of the lip. Might even be able to find it thicker than the stock gasket. I realize you don't want a hardening sealer on the block side of the gasket but I would at least use Hylomar there.
R Proper Aluminum Sump Installation Austin Healey 13
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
J TR4/4A Aluminum Sump made for TR3-TR4? Triumph 15
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
I TR6 Aluminum trim ring band removal Triumph 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
R General Tech Aluminum oil gallery plugs Triumph 3
Martinld123 Aluminum Radiator Leak? Austin Healey 3
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
Griz Aluminum door trim Austin Healey 5
B TR4/4A Aluminum head water leak? Triumph 7
maxwedge5281 aluminum fender vents installation Austin Healey 14
JFS Wedge Aluminum Rad Triumph 16
Nunyas what to use on polished aluminum Restoration & Tools 4
Chancevought953 Black welt piping on aluminum surrounds Austin Healey 1
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
S Aluminum wing vents for BT7 3000 Austin Healey 1
Got_All_4 TR2/3/3A How to use these Aluminum tie tabs Triumph 7
maxwedge5281 aluminum body parts Austin Healey 15
SherpaPilot TR6 New Aluminum Radiator Triumph 4
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
KVH TR4/4A Aluminum Front Plate from Moss and BPNW Triumph 2
F How to paint/prime aluminum front valance BT7 Austin Healey 2
trotti Aluminum cockpit trim Austin Healey 0
Got_All_4 TR5/TR250 Roto aluminum wheels on ebay Triumph 8
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
maxwedge5281 fitting aluminum wings Austin Healey 5
T TR2/3/3A My after market aluminum side curtains won't stay in on front top! Triumph 6
