Timing Mark
Cujo
Member
Good Morning,
I am trying to locate the timing mark on the lower pulley for a 1970 MG Midget. I have washed it etc and cannot find a timing mark anywhere (front or rear of the pulley). Any suggestions?
Thanks
64rocksprite
well..with no replies, I'll tell ya what little I know. On my early 1098 (no dampener) there is an obvious "v" slot cut into the pulley.
On my '74 engine (with dampener)..it was harder to find, but still there. Pretty sure it is on the engine side of the pulley.
I'm sure someone will answer with more in-depth answers.
jlaird
Should find a v slot cut in the pully.
Billm
On the 1275 (which normally has a damper (big, thick)pulley the line is really just a scratch mark on the big part of the pulley. I have found that it is best to find it from the top of the engine (taking off the generator makes it easier to see) and paint a white stripe on it. If you try to find it from the bottom without the white stripe you had better have VERY good eyes!!
BillM
Gerard
More of a square notch... like so...
drooartz
There's a special place reserved for whichever engineer thought that putting the mark and pointer at the bottom was the right thing to do. The MGB is the same way. Hap moved the Sprite's to the top, I really need to do the same with the B.
Just plain stoopid.
ABfish
Just plain stoopid.
It's on the bottom! Holy crap, who'd a thunk it! I spent a few minutes last night looking for the timing mark and pointer on my (new to me) Sprite with no success. I guess 20-plus years of fooling with classic American cars did not adequately prepare me for Sprite ownership.
That'll make it sort of hard to hold the timing light and rotate the distributor.....
Platinum
An exercise in gymnastics, AB. :wink:
Deleted member 8987
Wait until you come across a vehicle where you have to look through a gap in the bell housing for the timing mark.....
drooartz
I was checking the timing on the B last weekend and pressed my wife into service to man the accelerator while I checked things.
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
K TR2/3/3A Timing mark..... Triumph 1
R TR4/4A TR 4 Timing mark Triumph 10
A TR6 Timing mark Triumph 16
pkmh Setting Timing Mark For BJ8 Austin Healey 9
rlich8 Timing Mark Moving Around Triumph 21
T Hmmm - no timing mark on the pulley. Now what? Spridgets 10
D BT7 Timing mark and pointer question Austin Healey 6
Bruce Bowker ignition timing mark Austin Healey 5
J 100/4 timing mark relocation Austin Healey 2
jbowlby Timing Mark Relocation Spridgets 5
D timing mark Spridgets 12
tony barnhill Timing Mark Relocation Spridgets 2
mgb4tim Wedge TR7 Timing Mark Triumph 0
RandallRK Timing mark on crank pulley Austin Healey 19
Woodie timing mark - found Spridgets 10
Woodie timing mark Spridgets 42
1973purplemidget Timing Mark MG 3
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D Cam Timing question. Spridgets 11
KVH General Tech Valve Timing--No Marks Triumph 20
drooartz MGB Question on timing and vacuum MG 11
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K TR2/3/3A Timing marks on pulley? Triumph 10
LAW75 Timing Chain Cover Gasket Austin Healey 12
Lin Ignition timing question Spridgets 2
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
A Timing cover access Spridgets 6
BN6_2197 BN6 Static Timing Austin Healey 2
vette Timing Marks! Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
J TR6 73 TR6 Static Timing Questions Triumph 6
P TR6 1970 TR6 Timing Question Triumph 2
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR4/4A New valve gears/timing Triumph 21
K TR2/3/3A Ignition Timing? Triumph 11
M 100-4 Timing Pointer Austin Healey 5
D TR2/3/3A Timing chain tensioner. Triumph 3
KVH TR4/4A No Marks on Timing Gear Triumph 30
Got_All_4 TR6 Newly purchased poor quality timing gear Triumph 5
vette MGB 74 1/2 Timing Specs. MG 16
