I have what may be a silly question, but here it goes.
If one leaves the carb mixture setting alone and then changes the timing, does this effect the mixture. In other words, if you were to put a colortune plug in the car and then start to change the timing would the color you see in the colortune change? If so which way.
This is more of an academic question but I am trying to wrap my mind around the interaction of the two with each other.
