Thoughts on compression ratio and fuel octane???
nomad
I realize its a different fish but I'm setting up a Datsun engine for a Midget and it looks like my compression ratio will be somewhere around 9.25 to 1. Octane of gas around here is 89 at best. Think it will work??? What are folks running in hot BMC engine's? 87 down to 84 is common and I suppose we can expect it to continue down. If I stay close to home we are going to be getting blender pumps for picking your ethanol mix and that would allow higher octane. Have'nt decided whether to go this route or not.
Kurt.
mrsprite
Kurt,
I'm not exactly sure what my compression ration is with my A15 & GX head, but it's probably in the 9.0 to 1 range. I generally use premium, which for us in Colorado is 91 octane, but I have used regular 85 octane with no real ill effects. You should be OK with the 89, but maybe can't advance the timing as much as you could with higher octane.
aeronca65t
You have a few choices:
You can do trial-and-error method.
You can simply keep reducing your timing advance and then test drive the car. If you hear "pinging" when accelerting up a hill at moderate speeds in 4th gear (approx 3500 rpm), you need to back off timing more. If it sounds OK, you can advance timing until you hear pinging (and then back it off a degree or two).
That's one way.
Generally, engines do not ping at idle speeds. They ping at moderate speeds after timing has reached its full advance. So, if you want to have a better idea of what the real advance numbers, you can adjust your *total* timing advance.
To do this, you'll need a degree wheel on your front pully (or see note below) and you'll need to check your timing at the point where you're sure it has reached max advance. On most engines, this is around 5000 rpm (or less).
In other words, you rev your engine to about 5000 rpm and check your timing (it kind of a pain in the neck and you don't want to hold the engine at that speed for too long).
With your compression, I'd start with 25 degrees (BTDC) of total advance and see how that works.
You'll still need to do the trial-and-error process of listening for pinging, but at least you'll know what the actual numbers are and you can adjust based on those numbers.
Just for example, on my racing 1500, with 100 octane race gas, I run 30 degrees of total advance (again, checked at about 5000 rpm). Like most racers, I have no idea what my timing is at idle speed because I never bother to check it at low rpm. It really doesn't matter much as long as the car will start.
Note: if you don't have a degree wheel, or don't want to buy one, you can figure out where "0" degrees is on your front pully and then mark positions of 10 degrees, 20 degrees, 25 degrees and 30 degrees. If you're decent at geometry, this isn't really very hard. This should be enough marks to figure out where your total timing is.
One other note: if you read British publications, they call it "pinking" and not "pinging". Just an FYI to prevent any confusion.
G'luck!
N
nomad
Thanks for the comeback folks. I guess one can always retard the timing but as I recollect from a MGB I rebuilt in the 70's, there is'nt anything to be gained if compression is to high. With the MGB I went to a smaller dish in pistons just before premium gas became unavailable. I fought the comp ratio as long as I had that engine.
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
C 1960 BT7 Thoughts Austin Healey 14
C TR4/4A TR4 Thoughts Triumph 15
C MGA MGA Thoughts MG 20
AngliaGT Thoughts/advice on Miatas? Other Cars 22
Joe Schlosser Thoughts on a long traffic Light Spridgets 11
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
D TR2/3/3A Any thoughts on this part? Triumph 6
M Next job[s] on Otto - thoughts? Spridgets 35
G TR4/4A Thoughts on my coolant Triumph 12
Jim_Gruber Thoughts on driving Bugsy with the hardtop installed. Spridgets 32
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
B Thoughts...rough running at cruise. Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
Rut TR6 Thoughts on this car? Triumph 10
D Thoughts on Paint Removal... Austin Healey 11
AngliaGT Thoughts on Volvo wagon? Other Cars 5
cmacmillan TR6 TR6 grille repair - thoughts? Options? Triumph 6
AngliaGT Thoughts on Miatas? Other Cars 11
J Thoughts on waxing new paint? Austin Healey 14
KVH TR2/3/3A Thoughts on This EBay TR3 Please Triumph 25
Brinkerhoff Thoughts on car lifts ? Restoration & Tools 13
N Spitfire New thoughts on a.c. in Spitfire Triumph 11
Mink TR4/4A Your thoughts/value of this TR4 Triumph 357
HealeyRick Nasty Thoughts - Driving Impressions Austin Healey 15
F Thoughts on aftermarket air cleaners? Austin Healey 12
B Wiring Harness Issues -- Any Thoughts? Spridgets 6
KVH Some Thoughts Entering the New Year Triumph 18
Flash_Harry Any thoughts on these spark plugs? MG 9
richberman Thoughts on canted car? Austin Healey 15
lbc_newbie thoughts on exhaust Spridgets 9
T TR2/3/3A Thoughts on a TR3a Triumph 12
TR4nut TR2/3/3A Any thoughts on TR3A overheating struggle? Triumph 19
M Some random thoughts on a cool, sunny day Triumph 9
John250 TR5/TR250 Thoughts on selling my restored TR250?? Triumph 33
glemon Blasphemy Impure Thoughts Triumph 22
JPSmit Bought a Tool Chest today - thoughts needed. Restoration & Tools 16
bugedd Thoughts on this radiator Spridgets 9
AN5Sprite Tunebug engine diagnosis, thoughts anyone? Spridgets 47
boxfullofyertoys Thoughts on DIY welding/bodywork Spridgets 27
Stick Thoughts on Spridgetech Fiberglass Bonnets? Spridgets 2
T TR6 Thoughts on Superchargers for a TR6 Triumph 25
bugedd Bonnet thoughts... Spridgets 3
John_Mc Mechanic error? Thoughts? Other Cars 19
JPSmit Expansion tank thoughts Spridgets 6
DNK Lift THoughts Restoration & Tools 14
