Thermostats for 1275
Woodie
This is the first fall I have had the midget, and although she starts up fine in the AM, I am running with a "cool Thermostat, the temp never climbs past the 1/4 point (half way from dead cold to the midpoint on the guage) I need to warm the engine and heater for the next few weeks till storage time. What generic thermostat does the midget take ( ie for what North american car, make model and engine plz)
GB1
Woodie:
I have tried the generic one and it was to tall for the housing, so I purchased one from Moss.
Patrick
Woodie
Woodie
my guage is not numeric left side of smile is C, bottom of smile is a thicker line, and right side of smile is H, part of dual temp/oil pressure guage
Some guage, see pic here, 5th one down https://www.cardomain.com/ride/2354952
jlaird
Actually what you guys have seems to be good engines and radiators.
Billm
The generic is the one for 1960's and 70's Chevy's. The ones for both 6 and 8's should be the same and have always fit all of my Spridgets. I use a 192 for mine and it works fine.
Bill
zimmy
just order from VB or moss...only a few bucks....think there is a 180 degree one that should get the heater temp up a little........z
dont forget the gasket.....
weewillie
Woodie go into Canadian tire and get a 14-4034-4 which is a 180 degree thermostat. It is the same one that is used on a myriad of us cars and trucks, astro vans etc etc $7 and change
Willie /ubbthreads/images/graemlins/canpatriot.GIF
Patrick67BJ8 Thermostats Austin Healey 34
Jim_Gruber 160 or 180 degree thermostats Spridgets 5
K TR2/3/3A Thermostats again.... Triumph 2
T TR2/3/3A Thermostats in Hot Summers and Moderate Winters Triumph 10
rlich8 Thermostats Triumph 4
K TR2/3/3A Moss original sleeved thermostats for TR3 Triumph 17
livinginthepast Thermostats: because I have no pride, Spridgets 32
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
