T-Series the copper pipe?
NutmegCT
Could someone explain the differences in the valve cover "ventilation" in these three photos?
I assume some air filter change/modification has gone on in the third photo, but can't figure out why that copper pipe is "open to the elements". Was it supposed to have a draft tube going down toward the block? Or is the valve cover (and pipe) just wrong for that style carburetor air filters?
Thanks.
Tom M.
Mickey Richaud
Emailed ya, but that chrome valve cover may be aftermarket (or maybe a chromed original), but the vent would've been oriented toward the now non-extant air cleaner box and connected there. Looks like in the first picture the vent does drop down below the engine. I would think that the one in the third picture could be a source of grime in the engine bay.
NutmegCT
NutmegCT
Thanks. So in the third picture, should the valve cover be replaced with one not having that pipe? Or at least, should there be an extension on the pipe like in the first photo?
I'm assuming in the second photo (with the pancake air cleaner), there's no vent pipe.
Tom M.
a/k/a T-series Neophyte (and Digital Troglodyte)
Mickey Richaud
The third one has its valve cover on backwards. Oil cap should be toward the front. Here's a picture with stock air box:
NutmegCT
NutmegCT
So ... if the engine has the twin SUs with individual air cleaners ... there shouldn't be a "vent pipe" on the rocker cover?
Mickey Richaud
It needs the vent regardless of air cleaner type. That third one is plumbed incorrectly, seems to me. Not sure how the second one is vented; possibly through the oil cap.
NutmegCT
NutmegCT
Thanks. An interesting anomaly!
Take a look at this from an MG parts catalogue (Anglo Parts):
Index says Part 13, MGTD rocker cover.
Doesn't seem to show a vent pipe at all.
PAUL161
Things like this happen over the years when guys stray from the original factory hardware. The center pic is vented correctly, even though it has an after market casket valve cover. The first pic looks like an attempt to direct any fumes and or oil weepings over the side. In the third pic, the valve cover is definitely on backwards, not sure what the plumbers elbow is for, LOL. Never saw a pair of those pancake air cleaners that was worth their salt. The TD original oil bath air cleaner is about the best you can get to trap dust and dirt, reason they were so popular on farm tractors for many years. 60 + years is a long time for most of these cars to retain their original equipment, some of us were lucky enough to get a car with everything as factory still on it. I did have to buy a pair of Volks air cleaners on mine, only thing missing. PJ
NutmegCT
NutmegCT
Thanks Paul - so a TD should have the a single oil-bath cleaner, right?
I'm thinking that third photo in my first post, is someone's home-brew modification, adding the pancake cleaners to the carbs, but not knowing what to do with that rocker cover that's on backwards, and should have the pipe connected to an oil-bath air cleaner.
TM
PAUL161
A lot of cars trucks and engines in other equipment in the 40s and 50s had oil bath air cleaners, but over time and after parts stores started offering paper air cleaner inserts, a lot of folks went to them so they didn't have the mess when changing the oil and cleaning the oil baths and when improperly told that the paper filters were just as good as the oil bath, there was no contest. Caterpillar and International farm tractors with their massive air cleaners back then had an oil reservoir in the base, be amazed just how much dirt was collected in a short time. PJ
NutmegCT
NutmegCT
Thanks. But why would you want to plug up the vent hole? Shouldn't that vent hole be connected by tube/hose to one of the pancake air filters? So fumes/oil can be pulled into the engine and burned?
The original top-mounted oil mesh filter does that - and the exploded diagram above shows the intake tube at the top of the pancake filter.
PAUL161
Tom, the valve cover vent was among the first attempts at pollution control. Suck the fumes back and burn them. If the side vent is clear and breathes normally, there is no need for that top vent, as stated, an aftermarket decorative plug/cover and or a mini filter is available for it. unless of course you want it to be as factory. PJ
NutmegCT
NutmegCT
"If the side vent is clear and breathes normally, there is no need for that top vent"
Thanks Paul. My eyes aren't what they used to be. Where is the side vent?
TM
Jim B.
The TF has twin air cleaners similar to the first picture, BUT one has a spigot on the back side to connect to a vent hose.
NutmegCT
NutmegCT
Thanks Jim. My post #7 shows a spigot on one of the pancakes. Doesn't that connect (via rubber hose) to the vent in the rocker cover?
TM
andrea
Probably Valve cover are from MG TC- I have one 1946 TC and the air filter just connect with it-if you have pancake air filters is better to connect a pipe to one
to avoid gas overpressure in the valve cover
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
M brake pipe copper straps Spridgets 19
C copper brake pipe lengths Other Cars 12
C copper brake pipe lengths Austin Healey 2
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
TomMull Copper nickel lines again Restoration & Tools 0
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
glemon General Tech Nickel Copper Brake Lines Triumph 10
jfarris TR2/3/3A Which spark lug to use - copper/platinum/iridium Triumph 14
CJD TR2/3/3A Steel vs Copper fig of 8's Triumph 20
K TR2/3/3A Copper fuel line..... Triumph 6
S TR2/3/3A copper gasket sealer and push rods Triumph 10
Jim_Stevens TR2/3/3A A-type OD operating valve copper washer Triumph 3
S Will copper grease work for squeeling brakes? Austin Healey 3
tinman58 TR6 Copper washer? Triumph 5
DNK Copper in Brake Fluid Other Cars 2
Rut Copper rivets Spridgets 9
Patrick67BJ8 Copper Drain Lines for BJ8 Carb/Intake Manifold Austin Healey 30
dklawson Copper Composite Head Gaskets - Sealant or No? Triumph 6
bighealeysource Overflow copper tube from carb manifold ? Austin Healey 2
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
H Re-use of a Copper Headgasket Triumph 7
W Copper fuel lines Spridgets 10
Hairyone copper head gasket Spridgets 5
K Installing Head bolts and copper gasket Triumph 12
heliguy Copper or Copper Nickel Brake Pipes? Triumph 4
S TR2/3/3A TR3 Copper Head Gasket -- quick questions Triumph 8
MTribe special bolt for copper washer on sealing block? Triumph 2
6 Thor hammer restoration w/ copper heads Restoration & Tools 2
Morris Copper spray and head gasket instructions??? Spridgets 5
Steve_S Painting Copper Restoration & Tools 2
PATR8 Wedge Copper [my TR8] is out Triumph 2
davelgee copper head gaskets? Other Cars 2
healeyboz Copper Gasket Spridgets 1
B Copper gaskets for master cylinder, E-Type Jaguar 3
T head gaskets?-copper of steel? Triumph 4
R TR4/4A TR4A copper fuel line kits Victoria British Triumph 4
V Copper Brake Lines? Triumph 27
G Copper Brake Pipes for MIdget Spridgets 3
Z Copper spray and coated head gaskets? Triumph 0
D Copper core plug wires MG 3
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
R Valve Drain Pipe Austin Healey 13
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
Got_All_4 TR6 TR6 Down Pipe How They Last Triumph 6
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T Exhaust Pipe Hose Austin Healey 9
WHT Vacuum Advance Pipe Austin Healey 7
