MGB-GT SU Carburator Linkage -
AngliaGT
On our '67 GT.I made notes when I took it apart,but I can't find them.
The manuals don't show a very good picture.Does anyone have a detailed picture
of how the two rods go,& how/where the returns springs go?
Platinum
How far disassembled are the two rods, Doug? If the arm for the cable and the ends connecting to the carbs haven't been removed it will be easier to orient everything.
AngliaGT
AngliaGT
They're complete (no cables attached),but I'm not sure which one goes on
top,& which one goes on bottom.
And where does the one with the long arm on the middle go?
Platinum
The one with the arm is the throttle shaft, accelerator cable attaches to the arm. The "top" one. The other is for the choke.
AngliaGT
AngliaGT
Thanks! Now I need to take it apart (again!).
Any job worth doing right is worth doing at least three times.
Good thing I'm not getting paid by the hour.
Platinum
Our adage here is: "If you ain't done it three times, ya ain't done it at all!"
PAUL161
Doc, Only 3 times!!! LOL :devilgrin:
Platinum
PAUL161
:cheers:
Platinum
Please look thru the dirt and missing shaft in the right carb, this is a set needing rebushing, I "substituted" a DCOE Weber on the B.
EDIT: Looking at the pix again, the choke rod is upside-down.
K TR2/3/3A TR-3B carburator issues Triumph 2
algot1901 Carburator 50 Prefect 1172cc engine 10hp Other British Cars 4
glemon Carburator Contentment Ahhh! Triumph 1
J TR2/3/3A carburator decisions for TR3A Triumph 48
hondo402000 Weber Carburator rebuilding DCOE Triumph 14
bcbug Replacing carburator on Midget Spridgets 16
J Carburator draining Triumph 3
R carburator issue Triumph 1
J Zenith Stromburg 175 carburator tune? Other British Cars 3
P Cleaning carburator air filters Austin Healey 2
S Backfire through rear carburator Austin Healey 18
R Gas leaking from the carburator - help Triumph 8
T Gas running from carburator tube?? MG 1
Todd78d Bugeye choke linkage Spridgets 5
Todd78d Choke Linkage Photo Austin Healey 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Sopwith_Camel linkage jag mk2 Jaguar 1
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
Michael Oritt Clutch Linkage Austin Healey 19
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
M Choke Linkage Austin Healey 3
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 29
C Jammed Throttle Linkage Austin Healey 3
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
Sarastro TR4/4A Stromberg linkage question Triumph 4
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
doc50 73 Midget Carb linkage confusion Spridgets 5
K TR2/3/3A SU horizontal carb linkage rod? Triumph 3
D BT7 tri-carb linkage set up Austin Healey 23
J Wanted WANTED; XK150 Triple Carb linkage Jaguar Classifieds 0
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
K TR2/3/3A Sloppy SU linkage and DIY bellcrank repair? Triumph 6
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
Rut TR4/4A SU throttle linkage and brackets Triumph 5
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
S TR2/3/3A Linkage issue? Car stalls when braking hard Triumph 17
MY66AH Throttle Linkage Spridgets 9
H T-Series Need carb linkage info for my TD MG 1
K TR2/3/3A Auxillary carb linkage return spring? Triumph 2
B Longbridge 100-6 Throttle Linkage Pictures - Any Out There? Austin Healey 27
F Gas pedal linkage BJ8 Austin Healey 6
S TR4/4A choke linkage Triumph 2
mgedit TR2/3/3A Link Rod Lengths Accelerator Linkage Triumph 2
GTP1960 TR2/3/3A Rear shock linkage orientation? Triumph 2
B Carb Linkage Issue [3000 MkI] Austin Healey 6
