Stuck again on the other than British car forum
Rut TR4/4A Stuck clutch, again Triumph 19
KVH The Shifter Again--and I'm Stuck Triumph 10
J TR6 Stuck again with the floorboards for a tr6 Triumph 9
J TR6 stuck again - ignition switch removal on a tr6 Triumph 14
J TR6 Stuck again. TR6 axel removal Triumph 11
Morris Stuck valve...AGAIN!!!! Spridgets 15
Morris Valve Stuck Again Spridgets 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
R Healey 100 Dipstick Stuck Austin Healey 12
DrEntropy General MG Stuck splines? MG 3
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
KVH General TR Shifter Stuck Triumph 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
L Stuck in Overdrive Austin Healey 10
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
A MGB Stuck water temperature sensor MG 26
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
R TR2/3/3A Help, I am stuck, or think I'm stuck Triumph 32
J TR2/3/3A Oil drain plug stuck Triumph 10
drooartz MGB Stuck in now, engine swap time MG 13
N Stuck Needle Valve - Rough Running Austin Healey 15
M battery helmet stuck on post help Austin Healey 8
JimLaney 1098 stuck lifters problems Spridgets 5
Michael Oritt Oil release valve plunger stuck Austin Healey 9
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
D TR2/3/3A engine :"stuck" even before it starts! Triumph 28
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
nevets stuck rear brake drum Austin Healey 18
D TR4/4A badly stuck suspension sleeves Triumph 7
jfarris TR2/3/3A Head stuck on block Triumph 8
R General Tech Pressure Plate Stuck? Triumph 5
R Pressure Plate Stuck? Austin Healey 3
R stuck valve Austin Healey 14
C Overdrive stuck Austin Healey 10
T TR4/4A Geez - this head is really stuck on the engine Triumph 6
B stuck in 4th gear bj8 Austin Healey 8
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
Rut Stuck fasteners Spridgets 1
T General Tech Brake caliper - piston stuck Triumph 4
trotti Stuck drum - any ideas? Austin Healey 5
KVH General Tech Removing Stuck Head Studs from Block Triumph 18
bugedd Looks like you guys are stuck with me Spridgets 10
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
J Rear spring front pin stuck Austin Healey 8
