Straightening Steel Rims
mgedit
I'd like to use original steel rims on my 56 TR3 restoration. I have a number of rims, but most are not exactly straight. Anyone have experience (good or bad) with having rims straightened? Are they as strong or are they weakened significantly by the straightening process. There is a local shop that has the equipment to do the work. Any advice/suggestions? Cheers, Mike
Brinkerhoff
Mike , I have a lot of steel TR3 rims. I'm sure I could spin four or five and check them if you were interested. contact me off list if you are interested. Kevin
NutmegCT
My experience: if you want to drive the car, don't try to straighten bent wheels and drive on them. If it's just the lip of the rim (where weights are mounted), maybe ... but if the center of the wheel is bent, straightening it will weaken the steel. Others here have said the same thing.
I took three original steels (TR3) up to Boston for professional straightening, as each was bent out of true and wobbled when driven.
No improvement whatsoever - but they did look better. Bought four new steel wheels, put the same tires on them - wobble completely disappeared.
Just my two cents.
Tom
TR3driver
Great Pumpkin - R.I.P
:iagree:
Even "as strong" may not be strong enough. They are known for cracking in the center. ISTR one of the "Comp Prep" books even suggests welding an extra piece in to help reinforce them.
angelfj1
NutmegCT said:
Tom: I was under the impression that these wheels have not been available for many years/decades!
Do you mean you bought NOS wheels or is someone making these again?
NutmegCT
Sorry. I should have said four new "Minilite-style" wheels from Moss Motors.
Tom
Tosh
Sent an out of round steel TR6 wheel to Wheel Collision Center some time back.
They returned it with a note stating that they were unable to straighten the wheel.
Bought a set of new Kønigs and never looked back.
Keep on.
mgedit
mgedit
Thanks for the replies. The shop I talked to discarded the majority of the wheels I brought to him as the hub part was damaged or out of round. He told me those could not be restored. We were able to find 6 or so that he can work with. He is going to take the best 5 and straighten them. The shop has been in business since the 40s and has the machine they use to do the work (as well as an operator) dates back to the 50s. I had a good feeling about the shop and the proprietor during my visit and and going to see how this works out. If it is a success, I'll be happy. If not, experience gained. Other TR3 owners have told me of their success with having rims repaired and they have driven many happy miles on the rims. Guess only time (and finishing the restoration) will tell. Cheers, Mike
mgedit
mgedit
Forgot to add, that those wheels look very nice Tom. Are those the 5.5 inch wheels? If so, what tire size are you using and did you have any fitting issues? Cheers, Mike
NutmegCT
Hi Mike. Yep, those are the 5.5 wheels; I think they were on special for $169 each at Moss a couple years ago when I bought them. I got Kumho 758 tires (165/80-15), about $45 each. Really like them.
Tom
Don Elliott
Mike - How did the straightening go ? How much per wheel ? I saw recently that someone had 4 rims for sale for $500.00 total and he didn't say if they were straight or bent.
mgedit
mgedit
Sorry missed your post Don. I've given up on trying to straighten the rims I have. Only 2 of the 15 could be salvaged. I will use one for the spare and have bought alloy minilite-style wheels instead. Price to straighten is quoted as $35 per wheel, but he charged me less as we could not find 4 that could be used. It is just not worth $500 to experiment with steel wheels from another source. My experience suggests the likelihood of having usable wheels is pretty low. Cheers, Mike
Brinkerhoff TR4/4A Straightening a TR4A IRS chassis Triumph 15
T General TR Wheel Straightening Triumph 2
RJS General TR Straightening Oil Pan Triumph 5
K Straightening wire wheels? Triumph 15
M Frame Straightening Triumph 4
F Straightening front frame rails Spridgets 5
Nunyas straightening out a bumper MG 21
A Unibody straightening Spridgets 8
K TR2/3/3A The steel head stud washers? Triumph 7
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
S TR2/3/3A brass fitting from a steel brake line Triumph 2
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
Guido36 Stainless Steel Bumpers Austin Healey 5
B Stainless Steel Exhaust System Wanted Austin Healey 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
S TR2/3/3A steel bushings for the lower Arms Triumph 10
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
D Removing the last rust from pitted steel Restoration & Tools 11
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
T Trying to identify a steel plate part Austin Healey 2
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
B TR2/3/3A Tubes in steel wheels? Triumph 18
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
G For Sale Stainless Steel TR6 Bumpers Triumph Classifieds 0
I Stainless steel exhaust. Austin Healey 5
K TR2/3/3A Pressed steel body plates?????? Triumph 7
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
D TR2/3/3A TR3 Steel Wheels Triumph 7
busybrit TR4/4A Steel dashboard color Triumph 1
JimLaney How to treat media blasted steel Spridgets 3
B ISO two[2] steel road wheels, Morgan Other British Cars 0
KVH General Tech Steel Wool on Rod Bearings Triumph 9
T TR2/3/3A TR3 steel wheels Triumph 6
Gerry M TR6 TR6 Steel Wheel Question Triumph 3
simon1966 The jigsaw puzzle in Aluminium and Steel Commences. Austin Healey 7
busybrit TR4/4A TR4 Steel dashboard color Triumph 8
D TR2/3/3A Tubes in steel wheels? Triumph 15
DornTRoriginal TR2/3/3A Stainless Steel Exhaust Installation Triumph 4
J TR2/3/3A TR-3 Steel Wheel Repair Triumph 3
M Front steel brake lines Spridgets 9
BillyB62 TR2/3/3A Factory steel hardtop Triumph 14
