Steeging Box Leaks
Anyone have ideas on why a steering box would start leaking after years of dry service? This doesn't appear to be the typical leak through the seal around the rocker shaft; but may be coming from the front plate. There's no moving parts where it's leaking, and no plausible pressure buildup in a steering box, so what could it be?
Bob_Spidell
Argh ... Of course I meant 'steeRing box.' That's what I get for posting late at night.
Thanks Steve. I've already tightened the olive cover nut and the front plate nuts. Gasket failure is a possibility; sure hope the case isn't cracked.
TimK
Use Penright gear grease, no leaks, no matter what.
RAC68
Hi Bob,
I would second Tim's suggestion and would probably refill with John Deere Corn Head or Penright grease but after determining the cause of the leak or if I felt reasonably confident everything was operating properly.
All the best,
Ray(64BJ8P1)
bob hughes
Mmmm, I have Penright in my steering box and very good it is too, no major leaks at the bottom, certainly not enough to worry about, but the shaft appears to be working when the steering is operated at a standstill and grease can be seen oozing out of the joint where the shaft joins the box, not a major issue for me but a PITA, as I do not understand why it should be moving. BTW I believe that I have a 100/6 steering column as my BJ7 was repatriated from the States and put back to a right hooker by a PO.
:cheers:
Bob
RDKeysor
Bronze
My '60 BN7 dumped its steering gear oil without even a previous hint of a leak. I went the John Deere corn head gear route and haven't looked back. I bought the standard grease cartridge, loaded it in my grease gun, removed the grease fitting coupling and pumped the grease into the box. Later, I went back and topped off the grease level. I did this after reading up on this topic and the characteristics of this particular grease, among these is a lump of this material doesn't slump like typical greases. This is apparently a key requirement for corn head units. No, I won't replace the Penright oil in my shocks with this grease.
Keoke
steering box leaks, so what could it be?
Years of service-----:highly_amused:
L T-Series Gear box servicing cap. MG 5
Todd78d Sprit MK1 gear box filler Spridgets 2
T 1971 Fuse Box and Wiring Triumph 7
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
N TR5/TR250 Starter Box Assembly Leak Triumph 14
W General Tech 2500S starter motor and fuse box questions Triumph 3
Popeye General TR Old robbins top in box Triumph 7
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
R TR6 Heater box Triumph 6
W BN1 Steering Box Removal Austin Healey 11
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
W BN1 Steering Box Austin Healey 3
B MGB 1977 MGB Battery Box and Shifter knob MG 4
Martinld123 Steering Box Leak Austin Healey 27
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
F TR4/4A Locked out of glove box Triumph 1
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
W BN4 Steering box bushing. Austin Healey 2
Gundog61 BN2 Steering Box Leak Austin Healey 2
A MGB MGB a glove box door MG 10
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
AngliaGT MGB-GT How Do I get the Glove Box Opened? MG 16
C For Sale New in box 3:54 ring & pinion Austin Healey Classifieds 4
D Socket for TR3 Gear box drain plug Restoration & Tools 6
M TR6 Fuse box wiring mystery Triumph 9
B TR2/3/3A TR3a steering box rebuild Triumph 19
D TR2/3/3A Battery Box drain Triumph 9
Basil Now THIS is a tool box Restoration & Tools 6
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 8
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
TAS525 TR2/3/3A Steering Box Rebuild? Triumph 19
G Wanted - Glove Box Door for a TR3A Triumph Classifieds 2
Walter74 Steering Box End Play Austin Healey 2
G Glove Box Lock Austin Healey 2
S TR2/3/3A purchased a box of tr3 parts this weekend, Triumph 1
J Experience with High Ratio Steering Box? Austin Healey 15
Jayplum TR2/3/3A Steering Box end play Triumph 6
oldbagpipe Located Early TR4 Glove Box Hinges Triumph Classifieds 0
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
Michael Oritt Steering box lube Austin Healey 22
M TR6 Glove box lock. Triumph 4
Healey Nut Heater Box Installation Austin Healey 4
K TR2/3/3A The steering box again? Triumph 9
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
Jim_Stevens TR2/3/3A Glove box L-bracket Triumph 6
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
