TR2/3/3A Starting TR-2 for first time after restoration
R
Redoakboo
John,
On your other post you said when things are lined up and you the rock the engine #2 @ #1 will move? If the distributor is out of phase, do I need to re-install it 180 degrees?
sp53
OK you have the valve cover of-- At TDC compression stoke both valves will be close, and the rotor pointing at number # one. If the you have it 180 out, one of the valves will be open and the rotor pointing away from # one
sp53
Dick I contacted the double secret Swedish mulita/Navy, and we are sailing down with a Long Boat to start that TR-2 Should be there when get around the Horn.
steve
R
Redoakboo
I will meet you with my Pearson 29, car on board.
We tried to start it today, no luck. All we managed to do was blow the oil pressure line off the gauge, apparently wasn't tight.One of the guys in my club is a top notch TR man. We are towing it over there and have the experts look at it.
Next time I post, it should be running?? Is there a sure way do tell whether it's on the compression stroke or not? When I have it on TDC and rotor at #1 , by moving the fan back and forth, #1 & 2 go up and down. Think I have reached the Peter Principle.
Dick
bobhustead
At TDC compression stroke, which is what you need to find, both valves on cyl #1 need to be closed. It is the compression stroke and the next event is the bang (power stroke). If a valve is open at the bang, you get a backfire thru that valve. A valve is closed when you can move the rocker that operates it by hand. So, both rockers should be movable by hand at TDC compression stroke. If either rocker does not move by hand, you are somewhere else in the sequence.
Bob
PS If your rockers are moving with the pointer/crank pulley indicating TDC, you are TDC on the exhaust stroke. If your rotor is, at this stage, pointing at plug wire 1, you are 180 degrees out with the dist.
CJD
It sounds like you may be 180 deg out on the dizzy. Let's start like this:
1) Remove the distributor cap and turn the motor Clockwise from the front until the rotor points to the #1 spark plug. Check the timing marks and they should be close to TDC, within 20 degrees or so. Center up the TDC mark.
2) Now, remove the valve cover and look at your rockers. There 8 rockers, and we will call them #1 through #8 from the front for this step.
a) Jiggle the #1 and #2 rockers, they should have the lash you set...about .012". The key is that the rockers #1 and #2 should jiggle slightly .
b) Try to jiggle the #3 and #4 rockers. One or both should be locked in place and not jiggle at all.
3) If step 2 above is good, button it up and double check your initial timing. If step 2 above is backwards...i.e. #1 and/or #2 rockers are locked, and #3 and #4 are loose...then you are 180 degrees out on the distributor. If that is the case, turn the motor one turn clockwise to the next TDC...and remove and re-install your distributor so the rotor points to the #1 spark plug.
There are other ways to accomplish the above, but I think this is the quickest and simplest to get you going. Other things could be off, so re-checking valve lash might be worth while. Also, it's possible the timing marks are not accurate, as the pulley can be assembled out of phase too. If anything above does not seem right, then let us know and we can determine from there what is going on. Best of luck!
CJD
Just thinking of what can happen on an initial start...some things I've had trouble with are:
..Dizzy 180 deg out
..If timing it to advanced it will pop and stop the cranking cold.
..Timing marks off, so they do not correlate to the actual TDC
..Fuel not getting to the bowls...easy to check. With air cleaners off, make sure you can see fuel at the needle in the throat of the carbs. A squirt of starting fluid can double check for fuel starvation.
..of course any of the normal ignition issues, like coil, points not set right, and the like. If you get a flash with the timing light when turning the engine over, then these are NOT a problem. If you can't get a flash, then there is an ignition issue.
..plug wires mixed up.
That's the main stuff. If the cam timing is off, that can cause problems. The best check for proper cam timing is a compression test. Good timing should give you 120-170psi on a new motor, and pretty consistent across the cylinders.
pdplot
Once again, I repeat then old mamtra - if its got gas and got spark and both get there at about the same time - its got to run. Maybe not great, not even good, but its got to run. A squirt of starting fluid in the carbs will cause a start if its fuel related. If you can get the points to spark and a spark to jump from the coil lead to the block your ignition is probably ok. Its the timing thing, Make sure your points are opening between .012 to .015. Also make sure your fiber washer on the points isn't shorting out.
sp53
I was taught to place my finger or thumb over # 1spark plug hole with the plug removed then turn the motor over; the compression will push your finger or thumb off with clear push. At that exact point stop turning the motor over and look at the marks. That is TDC compression stroke . This usually causes the mark to go past a little, but you can back it up that little bit.
steve
R
Redoakboo
Paddy Lives!!!!!!!!!!!! A buddy, electric gifted, came over and I followed the pic's I took of the engine before I pulled it out. I had every plug wire in the wrong hole. After we sorted that out, BANG! it started. We set the timing right at 4 degrees before TDC. It is still going into the experts this week to sort some of the wiring connections, and let them drive it to check out the transmission operation.
I have some leaks to tend to, oil and gas. I have it jacked up as I think it's the gauge line coming out of the filter housing. And of course I have the usual wonderful SU leaks.
Horn honks when you put A2 fuse in, grounded somewhere. I am going to let the experts sort the 4 wires coming out of the Steering column. They don't follow the wiring diagram colors. I have a light green, green, a dark green and a purple wire coming out of the steering column.
The Saga continues????? Dick
R
Redoakboo
Had a few leaks I had to contend with. Fuel gauge not working and Temp gauge acting weird. It starts off at 85 and after the car runs for about 5 min, it jumps to 235??, and the bottom of the radiator is still cool?
sp53
That is wonderful those things happen all the time on new startups--- heck you got it together and it Runs after……….. I will turn the Long Boat around at Cap Disappointment with an Elk Horn . There really is a place here named that (google it)
Great news I needed some
Steve
R
Redoakboo
I had gas and oil on the floor, after running the engine for 15 minutes. Loose oil line feeding gauge and loose fitting under the gas shut off valve. Couple of gauges not working, fuel and temp acts funny. Nice to see the oil pressure sitting at 50 psi ! Timing was spot on at 4 degrees before TDC.
Towing it to a great British repair shop next week to make sure transmission O.K. It ran very smooth, valves clacked for a minute until oil got to them. Only one was to tight.
Dick - We are going on a Viking trip to Alaska summer of 2022. We cancelled France next year; to early with Covid still around.
sp53
A tr2 wiper motor wires different than tr3 wiper and I think you said you have tr3 engine, so I was suggesting maybe other components might be later. If you look at the wiring diagram, the gauges are labeled incorrect; it has the gas gauge and temp gauge mislabeled. You friends probably know that, but in my experience not many people know the little things about a tr2. Here you have John and Long door and they experience
R
Redoakboo
It has a TR-2 engine. I put a new 2 speed wiper system in it as the old one was so corroded I didn't think it was worth what they wanted for a re-built one. I found the fuel gauge problem. A1/A2 fuse blown.
Madflyer
So did it start and run well enough to adjust all that needed no leaks water temp good oil pressure came up fine no fires.. Sorry I mist a Thread or two and the brakes. Madflyer
R
Redoakboo
Carbs seem to be set good, ran at 1500 for about 15 minutes. Had a couple oil and gas leaks, nothing a few turns on a fitting couldn't correct. Haven't tried to drive it yet and will install seats next week.
No fires, one back fire.
Jayplum
I am getting ready to try and start my TR-2 after a total restoration.The wiring, other then front lights and horn are connected. Valves are adjusted to .013. Has water and gas. Point set at .015. Have a timing light to set timing if it starts? I have turned the engine over several times, no bad clacks. When setting the timing, should the vacuum advance be connected?
Brakes and clutch system have been bled and master cylinder is full. Transmission and engine have oil.
What have I forgotten?
Dick Vinal[/QUOTE
Your story is sooo familiar. I just finished a year long restoration on my '57 TR3. The trials and fears you encountered are the same.
Hang in there, I fought though all these and have mine on the road with good performance and am enjoying life.
CONGRATULATIONS on saving yours and keeping on motoring.
Got_All_4 TR6 Starting my frame restoration Triumph 32
J TR2/3/3A Starting my TR3 A restoration Triumph 8
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
me61ic Starting the restoration of my BJ7 Austin Healey 15
Magyar Starting my restoration.... again Austin Healey 12
September_1968 Starting a restoration Spridgets 7
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
mgedit TR2/3/3A 56 TR3 Starting Issue Triumph 9
M Starting from cold Austin Healey 2
R Very Difficult cold weather starting problems! Austin Healey 21
R TR4/4A Starting TR4A after 30 years Triumph 12
R winter hard starting BJ7 Austin Healey 16
P Jump starting a positive ground BJ8 Austin Healey 4
W starting motor Jaguar 0
D TR2/3/3A Starting my Bodywork journey. Triumph 166
P TR6 Quick starting Triumph 2
Joe Reed General Tech Starting a screw in a tight location... MG 9
P TR6 TR6 hard starting Triumph 24
stretchit2 Starting Issue Austin Healey 6
M TR6 Intermittant starting problems Triumph 4
Willie_P TR4/4A Starting long dormant TR engine..start up procedures? Triumph 10
