Starting procedure for 1975 Daimler 4.2
Alfasudcrazy
Member
As a new owner of a 1975 Daimler 4.2 I was just wondering is there a special 'knack' (special way) in starting a Daimler. Mine starts all right but it takes about five attempts before it does. Do you pump the gas pedal first or leave it alone. Does the automatic choke engage automatically or do you have to do something to engage it.
My Daimler has the twin carburretors - it is stored in a dry garage abd the battery is very good. /ubbthreads/images/graemlins/patriot.gif
piman
Hello ASC,
there could be a slight leak (weep is probably more accurate) from the jet connection to the float chamber. If so switch on the ignition and wait 30 to 60 seconds before cranking, If it starts promptly then that is the problem, the float chambers are low on fuel and need to fill up. The automatic choke is just that.
Alec
John S Farrington
Pumping the accelerator pedal on an SU or ZS carburetor equipped car does not accomplish anything. Nor does a fuel injection car respond to acceleretor pumping. You must make sure that your automatic choke is working and adjusted properly. I personnaly prefere to convert the "waterchoke" on the ZS carbs to a manually operated choke since the choke is prone to not work. A manual pull knob on the dash for choke operation will make a vast improvement. Conversion kits for the manual choke are available from Moss or many other suppliers.
Alfasudcrazy
Alfasudcrazy
Member
Thanks John - yes I reckon its my automatic choke not coming on - must investigate those manual choke kits
piman
Hello ASC,
I'm fairly sure, if yours is a UK spec Daimler, that you have S.U.'s not Zeniths and it may not be that easy or even desirable to convert to a manual choke.
I suggest that you get a manual and investigate the Auto Enrichment Device workings.
Good luck,
Alec
S Proper Starting Procedure After Winter Storage Triumph 12
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
mgedit TR2/3/3A 56 TR3 Starting Issue Triumph 9
M Starting from cold Austin Healey 2
R Very Difficult cold weather starting problems! Austin Healey 21
R TR4/4A Starting TR4A after 30 years Triumph 12
R winter hard starting BJ7 Austin Healey 16
P Jump starting a positive ground BJ8 Austin Healey 4
W starting motor Jaguar 0
D TR2/3/3A Starting my Bodywork journey. Triumph 166
P TR6 Quick starting Triumph 2
Joe Reed General Tech Starting a screw in a tight location... MG 9
P TR6 TR6 hard starting Triumph 24
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
stretchit2 Starting Issue Austin Healey 6
M TR6 Intermittant starting problems Triumph 4
Willie_P TR4/4A Starting long dormant TR engine..start up procedures? Triumph 10
S Hard starting on Webers from cold Austin Healey 12
