Sputtering in left hand turns
drooartz
So on my drive last weekend I noticed the following:
1. In a reasonably quick left-hand turn, say one where you're driving reasonably hard, the engine will eventually sputter as if it's out of gas.
2. In the same sort of right hand turn, no problems at all.
How do I fix this?
Three rights make a left. :smile:
I'd check the fuel filter type/location/orientation, and how firm the float bowl spacers are holding the bowl. I think the floats swing inline with the car unless the lids are oriented wrong.
Or... it could be electrical if there is something swinging over and shorting the coil/dist wire (low tension).
2091351
Had the same problem when I was Auto-Xing back in the 70's (last century). The only way I was able to remedy it was to orientate one of the carb float axis N-S and the other E-W. After identification of the problem, I added a 90 degree fitting to the front carby so it pointed straight up and hooked the fuel input there.
Wasn't perfect running SU's, but was much better than before I changed.
YMMV
Good Luck-Steve
G
Mine did that and the float level was too high. (albeit due to too much fuel pressure raising the level.) IIRC, Hap did your carbs too so it might be a pressure problem. I only say this based off of my experience.
drooartz
drooartz
I had wondered about the fuel pressure. I'm running a Carter fuel pump without a pressure regulator. Worth a try to put one into the system and see if it cures the problem.
lesingepsycho
Sounds like it's already been nailed but I'm +1 for fuel pressure.
Pythias
I thought the racers trick to fix this was to add a spacer to the float chamber, effectively giving it more capacity?
PeterC
Get the other float bowl lids that use the free floating float rather than the hinged float. Minis use them. Look around Mini sites, you'll see them.
Also, if you spend some time searching, you can find needles and seats that are a larger bore... .100" and .125" versus the original .075. That allows the fuel in faster... it's a performance thing.
Also, make sure your ignition coil is tight.... honest, btdt.
Peter C
G
Based on my experience I'd say that's it. They're only supposed have 2-3 psi and that's what Hap set the float level for. ( You can run I higher pressure, but the float level needs to be set lower. The extra pressure overcomes the spring loaded part of the needle and fuel doesn't shut off till that bottoms out, which means the floats need to be set lower.)
So, seeing the carbs are 100% and you aren't running a reg, then (it would seem) you definitely have too much pressure.
With my floats set properly and fuel at 3 psi, hard turns were o.k. If I stepped up the pressure any (which I did) it would sputter on hard left hand turns. You could smell fuel too.
Put the reg on and I'll bet you 1.83 tacos that'll fix it. ( Not cause I have faith in my diagnosis, but I have faith that Hap set the carbs up right.)
drooartz
drooartz
I do get that.
Time to dig up the regulator and find some fittings for it.
Pythias
Use a good regulator. Those round ones are crap.
G
I HATE the round ones too, but I've never had problems with one. They just look too cheap IMO and cost WAY too much for what they are.
G
drooartz said:
I do get that.
HEY MISTER, don't forget my two tacos if it works !!!!
( it was only 1.83 if I lost.)
drooartz
drooartz
I've got the Holley regulator, just need scrounge up the fittings for it.
Tacos are on me if it fixes the problem, but you'll have to come out here to collect them.
Pythias
NAPA should have the fittings.
G
O.K, O.K, I'll cover the cost of shipping.
drooartz
drooartz
Well, I put the regulator in today and it is a *bit* better. Still sputters in harder left turns, but it seems to take a bit more to get there.
So maybe just one taco...
wkilleffer Sputtering/backfiring around left-hand turns MG 4
tr6web TR6 Sputtering help Triumph 6
F TR6 Sputtering at low rpm Triumph 16
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
F TR6 Sputtering along Triumph 14
bugedd Sputtering Spridgets 15
PeterK TR4/4A Stalled project, now sputtering Triumph 3
S BJ8 Sputtering at High Engine Speed and in Overdrive Austin Healey 36
J MGB 69 MGB sputtering problem MG 5
nevets sputtering issue fixed...it was the timing Austin Healey 4
Bremer TR2/3/3A TR3A sputtering after 1 hour of driving Triumph 1
nevets sputtering redux Austin Healey 3
nevets intermittant sputtering follow-up Austin Healey 13
nevets Intermittent sputtering Austin Healey 38
K TR2/3/3A TR3A: Occasional sputtering and hesitation? Triumph 4
K TR2/3/3A TR3 Coil + Heat = Misfiring and Sputtering? Triumph 6
TR4A_IRS Sput...Sput...Sputtering? Triumph 19
Shane Fully choked and sputtering Austin Healey 3
Mio Sputtering under load Spridgets 27
U sputtering at start Spridgets 3
Wana UPDATE: Engine Sputtering Austin Healey 2
Don Elliott TR4/4A Sputtering when hot TR3 & TR4 Triumph 29
Luke_Healey Ignition/Sputtering troubleshooting? Spridgets 16
Wana Engine sputtering... Austin Healey 22
H Rough Idle and Sputtering Austin Healey 22
mabbott TR6 73 TR6 Sputtering problem? Triumph 17
Gray_Cat Sputtering/warmish Running BN1 Austin Healey 2
K ran fine, now sputtering/backfiring at speed MG 8
T TR6 TR6 Sputtering Triumph 12
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
M Left shock Spridgets 4
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
equiprx Left over parts from my 1994 XJS coupe project Jaguar Classifieds 0
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
Martinld123 My left rear wheel is locking up Austin Healey 16
B TR2/3/3A TR3 sag to the left [port sag] Triumph 10
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
M Wanted Bj8 left front wing Austin Healey Classifieds 3
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
Rut I’ve lost my mind, or what’s left of it! Spridgets 12
Tosh TR6 Engine dies slow left turn. Triumph 26
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
F BN7's left Austin Healey 9
