Speedo Cable Lubricant
Cain
Hello All,
The needle on my speedo has a lot of play. Before taking the speedo apart, I'd like to grease the speedo cable. What type of lubricant should be used for the speedo cable?
Thanks
Steven
graphite cable lubricant...its a powdery substance, not greasy or sticky. I put it on my tach cable, and I've never had to even bother with it again.
Geo Hahn
I agree with graphite... might want to wear your latex gloves. The stuff seems mostly harmless but is attracted to skin and a bother to wash off.
On TR3s & 4s you can just withdraw the inner cable without removing the cable housing from the car or detaching it from the gearbox. Just pull it thru from the speedo end, reinsert same way but twist & fiddle the last bit to get it to seat in the drive on the gearbox. Be aware it will be very messy -- don't let it drag across the interior.
Of course if someone has generously oiled it in the past you may want it all out where you can properly clean both cable and housing.
MGTF1250Dave
Aloha Cain,
Good advise from George and Steven. Bouncing needles on speedometers and mechanical tachs are usually fixed by lubing the drive cable.
Safety Fast,
Dave
Trevor Triumph
What are some suggestions to clean the cable and the housing? I notice I have a bouncing tach and speedo.
Although, the speedo acts a bit cantankerous even when the car is not moving. T.T.
Geo Hahn
I cleaned mine with that all-purpose standby: carburetor cleaner in the spray can.
Not suitable for cleaning the speedo head (internals) though as things are more delicate in there. I had to clean there too, what you use depends on whether you have the old painted on odo numbers (early maybe just TR2&3) or the later printed on plastic numbers. I had to repaint the odo numbers on the TR3A after I managed to wash them off!
Cain
Cain
Thanks for the info guys. I replaced the old broken speedo cable with a new one not too long ago and I just assumed the cable came pre-lubed. I'll probably run out at lunch and pick up some graphite lube at AutoZone.
algot1901 1950 Prefect Speedo Cable Other British Cars 8
George Zeck Speedo Cable? Spridgets 3
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
P TR6 72 TR6 Speedo cable Triumph 2
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
S TR2/3/3A Routing the OD speedo cable Triumph 9
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
S TR4/4A What is the routing for the speedo cable Triumph 2
longbridgehealey Speedo cable from 59 Bugeye Spridgets 1
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
E TR4/4A Speedo v Tach cable Triumph 2
F Speedo problem BT7 - cable rotates but speedo does not Austin Healey 25
M TR2/3/3A TR3 Speedo cable Triumph 4
RJS General TR Speedo Cable Lubrication Triumph 7
RJS TR4/4A OD Speedo cable length? Triumph 3
S hole for speedo cable Austin Healey 1
S hole for speedo cable Austin Healey 6
C Speedo cable Spridgets 8
S bj8 speedo cable Austin Healey 4
M BT7 Speedo Cable Routing Austin Healey 3
S TR2/3/3A speedo cable tr3 Triumph 5
O TR2/3/3A TR3 Speedo Cable Routing Triumph 1
S TR2/3/3A TR3A inner speedo cable too long at trans. Triumph 5
SilentUnicorn 77 b speedo cable MG 1
O TR2/3/3A TR3 Speedo Cable Routing Triumph 3
longbridgehealey speedo cable 948 to 1275 Spridgets 2
B Overdrive speedo cable question Triumph 6
toysrrus TR2/3/3A TR3 Speedo Cable: Info Needed: Triumph 3
stretchit2 speedo cable Austin Healey 7
Tinkerman TR2/3/3A Speedo Cable Routing TR3 Triumph 12
glemon Angle Drive Speedo Cable Different Size Ends Triumph 12
J TR2/3/3A TR2/3 speedo cable Triumph 3
Pythias 5 Speed Speedo Cable Install. Spridgets 0
jvandyke speedo cable Spridgets 10
pjsmetana Speedo Cable Replacement. How? Triumph 15
bcbug 76 Midget speedo cable Spridgets 1
S speedo and tach cable color Triumph 5
mountainman TR2/3/3A TR3 Speedo Cable Triumph 4
DrEntropy Alfa wearin' [out] a speedo [cable]. Other Cars 5
M Bugeye speedo cable Spridgets 4
T Speedo and cable Triumph 1
CraigLandrum TR2/3/3A TR3 New speedo cable squeal cause? Triumph 3
longbridgehealey speedo cable out Austin Healey 2
2wrench New parts and speedo cable woes Triumph 35
B Anyone got a 75 Speedo Cable? Spridgets 1
Bruce_B Datun 5 speed--where does the Speedo cable attach? Spridgets 26
R MGA Speedo cable routing MGA MG 2
T TR2/3/3A TR3 w/overdrive speedo cable routing??? Triumph 2
