MGA Speedo cable routing MGA
Ray7Smith
How does one route the speedo cable from the speedometer to the transmission? does it go through the firewall then down to the tranny?
Ray
Steve_S
Yes. IIRC, it exits through one of the holes by the MC, then down. I'd take a photo for you but I can't get to the MGA right now. If no one else comes through with one then I'll get it at some point.
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
S TR2/3/3A Routing the OD speedo cable Triumph 9
S TR4/4A What is the routing for the speedo cable Triumph 2
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
M BT7 Speedo Cable Routing Austin Healey 3
O TR2/3/3A TR3 Speedo Cable Routing Triumph 1
O TR2/3/3A TR3 Speedo Cable Routing Triumph 3
Tinkerman TR2/3/3A Speedo Cable Routing TR3 Triumph 12
T TR2/3/3A TR3 w/overdrive speedo cable routing??? Triumph 2
algot1901 1950 Prefect Speedo Cable Other British Cars 8
George Zeck Speedo Cable? Spridgets 3
P TR6 72 TR6 Speedo cable Triumph 2
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
longbridgehealey Speedo cable from 59 Bugeye Spridgets 1
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
E TR4/4A Speedo v Tach cable Triumph 2
F Speedo problem BT7 - cable rotates but speedo does not Austin Healey 25
M TR2/3/3A TR3 Speedo cable Triumph 4
RJS General TR Speedo Cable Lubrication Triumph 7
RJS TR4/4A OD Speedo cable length? Triumph 3
S hole for speedo cable Austin Healey 1
S hole for speedo cable Austin Healey 6
C Speedo cable Spridgets 8
S bj8 speedo cable Austin Healey 4
S TR2/3/3A speedo cable tr3 Triumph 5
S TR2/3/3A TR3A inner speedo cable too long at trans. Triumph 5
SilentUnicorn 77 b speedo cable MG 1
longbridgehealey speedo cable 948 to 1275 Spridgets 2
B Overdrive speedo cable question Triumph 6
toysrrus TR2/3/3A TR3 Speedo Cable: Info Needed: Triumph 3
stretchit2 speedo cable Austin Healey 7
glemon Angle Drive Speedo Cable Different Size Ends Triumph 12
J TR2/3/3A TR2/3 speedo cable Triumph 3
Pythias 5 Speed Speedo Cable Install. Spridgets 0
jvandyke speedo cable Spridgets 10
pjsmetana Speedo Cable Replacement. How? Triumph 15
bcbug 76 Midget speedo cable Spridgets 1
S speedo and tach cable color Triumph 5
mountainman TR2/3/3A TR3 Speedo Cable Triumph 4
DrEntropy Alfa wearin' [out] a speedo [cable]. Other Cars 5
M Bugeye speedo cable Spridgets 4
T Speedo and cable Triumph 1
CraigLandrum TR2/3/3A TR3 New speedo cable squeal cause? Triumph 3
longbridgehealey speedo cable out Austin Healey 2
2wrench New parts and speedo cable woes Triumph 35
B Anyone got a 75 Speedo Cable? Spridgets 1
Bruce_B Datun 5 speed--where does the Speedo cable attach? Spridgets 26
Mg_Bizzle New speedo cable problems MG 4
