So what do y'all think of modified Plus 2s?
tdskip
Hi guys - one of my TR4a's is going to be sold so of course I'm already spending that money. I've had an itch for a Plus 2 for sometime now and have some questions on how modifications impact values and resale.
The car has a scruffy interior. Exterior is driver quality. Both of those can be readily, if expensively addressed, although I'm not sure where I'd source door cards and carpet etc...
The chassis has been replaced with a Spyder Cars Zetec chassis that will accept a for Zetec motor although it has a twin cam in her now. The rear suspension has a Spyder Cars upper and lower arm rear suspension (no lotocones at the rear) with adjustable perch shocks.
Is the new chassis considered a plus, or does is an aftermarket chassis viewed as a negative?
Take me to school here guys.
Platinum
WOW!! That has some appeal. The Spyder stuff is very desirable. Amazed someone did it with a +2, though. They aren't real "popular" with most folk. Resale value is far under what I thing the things are worth. As for engine swap, WHY? That twink can be as much engine as you'd ever need. IMHO stuffing a Zetec in it would be "coals to Newcastle". Build the twin-cam up if you think more power is what you want.
Car handles as if on rails, BTW. Spyder frame and suspension make it even better.
T
tdskip
Hi Doc - she has the twink in her still. The Zetech will drop in easily, but I'd not do that unless forced and bribed.
How are running costs and what would I need to be aware of if I jump in?
Platinum
Standard stuff is the same as any other vehicle. Regular oil/fluid changes and such. It won't be real thirsty, either, unless you drive with yer boot in it all the time. The body was the first production Lotus (and likely the first production car, period) to be designed in a wind tunnel. Drag coefficient is lower than most things on the highway even today. Cd is 0.27. "Slippery"!!! :laugh:
Only "iffy" business is the water pump. Bean sells an "upgrade" to eliminate that issue. The Spyder suspension eliminates the other quirky issue of the donuts rupturing. Very cool.
T
tdskip
Doc (and guys) - what unobtainable interior bits do I need to be looking out for? This cars gauges have been replaced with modern ones.
Thanks
AngliaGT
Tom,
Are you going to keep this car? If so,I have a lot of
Cortina MKII parts that might work.
- Doug
Platinum
Platinum
Thanks
The center cover on the frame backbone is a rare bit. Dash is laminate plywood and can be reproduced. Seat material is available as repro but getting the heat-rolled design in the "basket-weave" inserts is more a job for an upholsterer.
It is likely the interior door handles are late MGB, most of the other stuff is pretty generic as well.
Guages? They were Smiths, there are repro ones around, and as I mentioned above, the cars are undervalued so you may still find originals for sale from +2s being parted out. That would be my only reason to suggest going over to that other site.
The temp gauge/OP gauge is the same one used in most other BMC/BL units. Depends a bit on what year the car is, as to what was fitted.
Window seal material can be had from a few sources, Bean is the "easiest" but THIS GUY is my preference for that stuff.
drooartz
So did you get a look at it? I'll admit that I like the lines of the +2 quite a bit. One old crate at a time for me, though. I'll just admire your collection (and efforts) from afar.
DNK
Lotuselan.net is fine but I want all info posted here too
P MGB 1980 MGB Modified Intake Manifold MG 7
Sherlock Triumph TR6 (rather modified) Spotted 2
jfarris TR2/3/3A Modified turn signals/brake lights on a 56 Triumph 6
D Modified carb sync tool. Austin Healey 11
K For Sale TR4A Grille...Modified for Lights Triumph Classifieds 0
R Modified XK 120 Jaguar 2
maxwedge5281 modified bn6 history Austin Healey 1
T Modified BE Shifter Cupola for Datsun 5 Speed Spridgets 7
GTP1960 TR2/3/3A the value of experience when setting timing on a modified engine Triumph 33
DerekJ 100 Le Mans - Dealer modified. Austin Healey 7
M TR4/4A What modified carby air filters to use on my TR4 RHD. Triumph 19
M Looking for opinion on keeping original parts for my modified Healey Austin Healey 8
L Modified Healeys featured in Healey Marque Austin Healey 8
Bremer TR4/4A Modified TR4 for sale Triumph 7
HealeyRick Modified Healey on Bring a Trailer Austin Healey 3
K TR2/3/3A Odd looking modified TR3 on Craigslist...saint luis obismo Triumph 24
J Wedge Modified TR-8 in California...I need help to pass smog...HELP!!!! Triumph 25
DerekJ Important, documented, 1953 DHMC modified 100 Le Mans for sale Austin Healey 8
glemon What do you think of this one? [modified 100] Austin Healey 10
KVH TR4/4A TR4 on Ebay [Modified Somewhat] Triumph 2
billspohn MGA Modified MGA MG 1
B Nicely done modified Sprite [NFI] Spridgets 14
aeronca65t LeMans Start [modified] at Turkey Bowl today Racing 7
B Is there a class for my modified healey Racing 4
HealeyRick My Next Modified Austin Healey 17
HealeyRick Modified Bugeyes Spridgets 12
Cottontop A Modified Healey Austin Healey 9
D Modified Banjo Steering Wheel???? Triumph 8
K TR2/3/3A TR3 SU Needles in relation to modified cam? Triumph 6
J Healey Skid pad numbers stock or modified? Austin Healey 15
JPSmit Modified Miatas Other Cars 0
aeronca65t modified Austin Other British Cars 7
T Wedge First drive in the latest modified TR8 Triumph 19
vping MGB Who has Modified MGB Air Cleaners? MG 14
AUSMHLY Healey banjo steering wheel modified to 15" Austin Healey 8
billspohn MGA MGA [slightly modified....] MG 3
G TR6 Non-modified TR6 Triumph 3
C TR6 Modified TR-6 [highly!] Triumph 8
C Spitfire Modified Spitfire [highly!] Triumph 2
C GT6 Modified GT6 [highly!] Triumph 10
billspohn TR2/3/3A Modified TR-3 [highly!] Triumph 17
Cottontop Modified AH Registry Web Site URL Change Austin Healey 0
soren_ak MODIFIED Austin Healey 8
vping Modified Thermostat housing for a '74 B MG 25
SCguy Wedge Modified brake proportioning valve for TR8 Triumph 3
T TR6 Modified TR6 drivability Triumph 11
nevets modified BN6 engine Austin Healey 5
T $35,000 slightly modified Midget Spridgets 13
martx-5 SU and Stromberg Carbs on Modified Motor Triumph 5
hondo402000 TR6 Monza exhaust modified for TR6 Triumph 0
