Size of socket to turn over 1500 engine by hand
G
I'm attempting to find out the size of socket that fits the 1500 engine so I might turn it over manually. I can't seem to find this info in either of the manuals I have.
Thanks,
John
JPSmit
1 13/16"
dklawson
I made an open end wrench for this task by welding up pieces of 1/4" thick flat iron from the home center. Can you get a socket and wrench down there with a radiator and fan in place?
The wrench I made was only used once when there was no water pump on the engine and the car wasn't on its wheels. Otherwise I would have rolled the car in gear or pulled on the fan belt.
Jim_Gruber
Try Tractor Supply or some type of Farm Supply store. Large sockets fairly inexpensive for the one or two time use.
tosoutherncars
As Doug suggests... if it's on the ground, a nice option would be to stick it in fourth and pull the car forward. Probably easier than trying to get a wrench in there.
Or, I cheat and stick a screwdriver in the blades of the alternator fan, and turn. Probably not in the shop manual, but... :wink:
G
Thanks for the tips. Engine is not in a car that can be rocked. Is for sale and has no belts or alternator on it. Tractor Supply had what I needed, and I turned the engine over and found it had no compression with plugs in. That was a quick "no sale."
John
jlaird
But I don't think you are going to get a compression guage to work hand turning an engine, at least not much.
racingenglishcars
Engine must turn over at least a couple hundred rpm and for at least 6 turns to register anything reasonable at all on the compression gauge. You should be able to feel something though, if it has oil in the cylinders.
The buyer should have known that. The fact that it turns over should make the engine worth something.
G
My stock car motor turned over just fine, even though the camshaft went through the lifter galley. On the other hand my MG motor was frozen at one time. You really can't "gauge" the compression by hand rolling over the motor- dissasemble it and look- or run it and see what happens.
G Socket size to turn over 1500 engine by hand Triumph 4
Obtong Rear Axel Socket Size? MG 3
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
CARSINC Spark plug thread size Spridgets 2
R Vixen 2500 Lug Nut Size? TVR 5
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Bayless What size battery for my '67 Sprite? Spridgets 5
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
S TR2/3/3A Vacuum Advance Union Size Triumph 1
T Radiator Hose Size Austin Healey 2
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
Joel Lester TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
B Exhaust Pipe Size Austin Healey 26
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
Healey Nut TR6 Headlight size Triumph 58
MadRiver TR6 Emissions Hose/Tubing Size? Triumph 2
JPSmit Not quite an LBC - but the size might be close :) Restoration & Tools 3
B TR4/4A Oil Drain plug size Triumph 14
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
69MGC MGC What size tires will fit nicely MG 2
M TR5/TR250 Compatible Modern Tire Size Triumph 5
J Nut size for BJ8 center console trim piece Austin Healey 8
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
D TR4/4A SU HS6 throttle spindle size Triumph 20
C Size or matching screw on cap for Trafalgar bottle? Austin Healey 0
Bayless What size fuel line for '67 Sprite? Spridgets 2
S Bugeye Radiator Tank Plug Size? Spridgets 24
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
K Abington Allocation Plate size? Austin Healey 1
R TR4/4A Door mirror base size Triumph 2
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
S TR2/3/3A Pixel primmer size Triumph 18
F TR2/3/3A Spare Tire Size Triumph 11
C Size of axle bearing nut Austin Healey 11
GeorgeC Steering wheel nut size? Spridgets 3
ckeithjordan TR2/3/3A Trim Hole Size Triumph 3
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
KVH TR4/4A Belt Size for TR4A Triumph 4
P TR2/3/3A Recomended enclosed car hauler size? Triumph 8
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
55modified Radiator sensor thread type size needed for bn1 Austin Healey 12
jfarris For Sale New TR3 Rod Bearings Big End Std Size Triumph Classifieds 0
George Zeck Wheel Stud Size? Spridgets 10
Jim_Gruber Size Matters Spridgets 3
