T-Series screw size
saltiga
Could someone give me the type and size of the 2 screws that hold the elbow on the thermostat housing, p/n323-040 item38 page 12 0f the Moss catalogue. saltiga
C Size or matching screw on cap for Trafalgar bottle? Austin Healey 0
P Fuel Float to tank bolts [machine screw] size?????? Spridgets 1
K TR2/3/3A Proper size of "set screw/bolt?" for top of trans..... Triumph 1
CanberraBJ8 screw size for window bracket? Austin Healey 3
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
J Windshield pillar to windshield frame screw size? Spridgets 2
K TR2/3/3A TR3 Dist points plate hold down screw size? Triumph 9
Newkie Center Console Bolt/Screw size? MG 1
Tinkerman # 4 Trim Screw Drill Size Triumph 1
Bruce_B Need Information on plug/screw size Spridgets 3
RedTR3 TR2/3/3A TR3 Clutch slave bleed screw size Triumph 4
nevets Condenser Securing Screw Austin Healey 14
B Surprise screw head Restoration & Tools 0
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
G HD8 Idle Adjust Screw Austin Healey 10
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
R Grille Top Cowl Screw Austin Healey 7
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
T C42 BJ8 generator long screw needed Austin Healey 2
C TR6 ZS 175 What does this screw do? Triumph 2
JimLaney Rocker shaft plug/screw delima Spridgets 3
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 1
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 2
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
M TR2/3/3A Where does this screw go? Triumph 6
B Rear Seats - Do I have to drill screw holes through the brand new leather upholstery? Austin Healey 13
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
Joe Reed General Tech Starting a screw in a tight location... MG 9
CJD TR2/3/3A Screw Post Coils Triumph 6
cmacmillan TR6 metering needle - no longer in a relationship with adjustment screw... Triumph 9
J SU HD6 - Slow Idle Screw Austin Healey 13
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
G Lens screw for AH 3000 BJ8 Austin Healey 1
R TR4/4A Assembling the interior - dash support and radio plate screw holes don't match up Triumph 4
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
Geo Hahn TR2/3/3A Steering Box Adjusting Screw Triumph 12
P BJ 8 broken hood frame screw Austin Healey 6
tinman58 TR5/TR250 Did I screw up? Triumph 4
Brooklands TR2/3/3A Set Screw Triumph 6
B TR2/3/3A anyone help me identify the screw attaching seat slide to the floor? Triumph 8
GBRandy Wedge TR8 AF Screw Triumph 1
A TR2/3/3A TR-3A Trunk handle screw Triumph 10
S TR2/3/3A little adjusting screw tr3 Triumph 1
Gliderman8 Removing stubborn screw Restoration & Tools 22
H Side marker lens retaining screw Triumph 6
NutmegCT TR2/3/3A TR3 hard top screw Triumph 5
wangdango '96 XJR reversed battery charge screw up... Jaguar 2
sparkydave Rear view mirror set screw Spridgets 0
W How big a screw up? Spridgets 5
