Screw driver
jlaird
Found a very nice British Bent wire screwdriver for under $20. Will be nice addition to Miss Agathas tool roll. Tool roll not really for use, just for fun.
Now have:
Jack
Jack wrench
Lug wrench
Have my eye on several other items as well. Will get there.
Need Tecalemit greese gun
Plug wrench
Points wrench and adjustment tool
Feeler guage
Air pump
what good is a bent screwdriver? :jester:
m
RickB
Oh - looking here:
https://tiny.cc/zi72i
Now I see what those belts are for on the back of my MK1 Midget cockpit divider.
I need to move that divider to my MK2 Sprite to replace the plywood that's in there now with something a little more original.
jlaird
jlaird
Yes that is my screw driver. Hope it gets here this comming week.
And yes that is also the correct grease gun.
J That screw driver MG 11
nevets Condenser Securing Screw Austin Healey 14
B Surprise screw head Restoration & Tools 0
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
G HD8 Idle Adjust Screw Austin Healey 10
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
R Grille Top Cowl Screw Austin Healey 7
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
C Size or matching screw on cap for Trafalgar bottle? Austin Healey 0
T C42 BJ8 generator long screw needed Austin Healey 2
C TR6 ZS 175 What does this screw do? Triumph 2
JimLaney Rocker shaft plug/screw delima Spridgets 3
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 1
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 2
S T-Series screw size MG 0
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
M TR2/3/3A Where does this screw go? Triumph 6
B Rear Seats - Do I have to drill screw holes through the brand new leather upholstery? Austin Healey 13
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
Joe Reed General Tech Starting a screw in a tight location... MG 9
CJD TR2/3/3A Screw Post Coils Triumph 6
cmacmillan TR6 metering needle - no longer in a relationship with adjustment screw... Triumph 9
J SU HD6 - Slow Idle Screw Austin Healey 13
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
G Lens screw for AH 3000 BJ8 Austin Healey 1
R TR4/4A Assembling the interior - dash support and radio plate screw holes don't match up Triumph 4
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
Geo Hahn TR2/3/3A Steering Box Adjusting Screw Triumph 12
P Fuel Float to tank bolts [machine screw] size?????? Spridgets 1
P BJ 8 broken hood frame screw Austin Healey 6
tinman58 TR5/TR250 Did I screw up? Triumph 4
Brooklands TR2/3/3A Set Screw Triumph 6
K TR2/3/3A Proper size of "set screw/bolt?" for top of trans..... Triumph 1
B TR2/3/3A anyone help me identify the screw attaching seat slide to the floor? Triumph 8
CanberraBJ8 screw size for window bracket? Austin Healey 3
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
GBRandy Wedge TR8 AF Screw Triumph 1
A TR2/3/3A TR-3A Trunk handle screw Triumph 10
S TR2/3/3A little adjusting screw tr3 Triumph 1
Gliderman8 Removing stubborn screw Restoration & Tools 22
H Side marker lens retaining screw Triumph 6
NutmegCT TR2/3/3A TR3 hard top screw Triumph 5
wangdango '96 XJR reversed battery charge screw up... Jaguar 2
sparkydave Rear view mirror set screw Spridgets 0
W How big a screw up? Spridgets 5
S Austin Healey 100 6 screw list Austin Healey 6
L Stripped windshield frame screw hole Spridgets 6
K TR2/3/3A TR3A Windshield Stanchion Screw Removal? Triumph 8
J Windshield pillar to windshield frame screw size? Spridgets 2
