Rocker shaft problem
billspit
Last week I was trying to disassemble the rocker arms for my Spitfire project. The pedestals were on the rocker shaft so tight I could not get them off. I fought with every one and was scared I may have boogered some of the up. Is the shaft supposed to be <span style="text-decoration: underline">that</span> tight on the pedestals? I'm considering opening the pedestals up a little to reassemble.
Moseso
Apparently, they are supposed to be that tight. On my TR3, I gripped the shaft in a padded vise and used a length of 5/16" allthread through the mounting hole to twist-and-pull them off. I intend to put them back the same way on the new shaft. The real trick will be lining them up so they sit flat on the head. I think the act of torquing them down will line them up the last little bit. I am using Joe Alexander's solid spacers between the rocker arms, so I'm going to have to get the spacing right too.
70herald
Yep they will be tight. After lots of years, a tiny bit of corrosion will develop between the aluminum and the shaft, and they will be difficult to get off. Just clean them up and put them on the new shaft. I will probably be easier to get them on the new shaft than it was to get them off the old. A bit of oil will help.
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
WHT Rocker Arm Shaft Replacement Austin Healey 21
G Installing New Rocker Shaft Assembly Austin Healey 3
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
D MGB MGB rocker shaft shims MG 1
JimLaney Rocker shaft plug/screw delima Spridgets 3
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
M TR6 rocker shaft install tr6 Triumph 2
KVH TR4/4A Rocker Shaft Lubrication, and Issue with Push Rods Triumph 1
S TR2/3/3A Bolting the rocker shaft Triumph 3
J TR2/3/3A Installing new rocker arm shaft. Triumph 6
DornTRoriginal General Tech Where is the Rocker Shaft Retainer Pin Triumph 2
TR6BobNF TR6 TR6 Rocker Shaft Assembly Triumph 1
B Rocker shaft spacing washers. Austin Healey 2
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
glemon Final Rocker Shaft Question Triumph 5
glemon Tuftrided Rocker Shaft Triumph 3
glemon Opinion/Experence Rocker Shaft Wear Triumph 6
rlich8 "Oil Screw" on Rocker Shaft Triumph 6
ekamm TR2/3/3A Tr3 steering rocker shaft bushing Triumph 1
6 more about the rocker shaft Triumph 12
6 rocker shaft Triumph 3
L Rocker Shaft Assy Triumph 7
7 rocker shaft Triumph 2
T Defective rocker arm shaft photo Triumph 12
T Rocker arm/shaft question Triumph 13
BOBBYR Rocker shaft rebuild Austin Healey 10
H Rocker Shaft assembly Austin Healey 1
chicken Rocker shaft Austin Healey 3
T Rocker shaft cleaning Triumph 19
Moseso Rocker shaft dis/reassembly Triumph 3
Tinkerman TR2/3/3A Locking screw on rocker arm shaft, TR-3 Triumph 4
D Oil Spraying from Rocker Shaft - BJ 8 Austin Healey 10
M Rocker arm shaft question Austin Healey 11
Tinkerman 60 TR 3 post 60000 Rocker Shaft Pedestal Bushings Triumph 2
C Rocker arm play on shaft Austin Healey 12
M Rocker Arm Shaft Triumph 4
S GT6 GT6/TR6 rocker shaft oil problems. Triumph 5
Y TR6 TR6 - Secondary oil feed to rocker shaft Triumph 12
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
Hamish Racing General TR Rocker cover identification please. Triumph 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
H Rocker Cover Data Plate Austin Healey 15
Twit TR4/4A 1.5 in outside diameter rocker cover pipe Triumph 3
