rocker shaft
72spit6
Member
I started the engine rebuild and got the head off and out to be redone with the rocker shaft sitting on the work bench. I need some tips and tricks on how to clean it up and make sure that it is in good working order for when the engine is finished.
TR3driver
Great Pumpkin - R.I.P
My advice: Send it off to Rocker Arm Specialists and have them recondition it. In spite of their awful web site (which they claim they are trying to improve), they did a great job on my TR3 shaft, and charged only about what the parts would have cost me to do it myself.
https://www.rockerarms.com/contacus.html
But if you want to do it yourself, you need to disassemble the shaft (remove the rockers, springs and pedestals). Look for wear on the tips of the rockers (which should be a smooth curve in one axis, but straight from front to back), on the shaft itself, and where the rockers ride on the shaft. Also check the adjustment nuts, and the tips of the adjusters where they ride on the pushrods. The springs should probably be replaced just because they are old, even if they aren't visibly worn.
DougF
I agree with Randall on Rocker Arm Specialists. They will bush and reface the rocker arms to your specifications. I had already purchased a new rocker shaft, but have seen their finished product. Quite good.
Good work for a good price.
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
WHT Rocker Arm Shaft Replacement Austin Healey 21
G Installing New Rocker Shaft Assembly Austin Healey 3
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
D MGB MGB rocker shaft shims MG 1
JimLaney Rocker shaft plug/screw delima Spridgets 3
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
M TR6 rocker shaft install tr6 Triumph 2
KVH TR4/4A Rocker Shaft Lubrication, and Issue with Push Rods Triumph 1
S TR2/3/3A Bolting the rocker shaft Triumph 3
J TR2/3/3A Installing new rocker arm shaft. Triumph 6
DornTRoriginal General Tech Where is the Rocker Shaft Retainer Pin Triumph 2
TR6BobNF TR6 TR6 Rocker Shaft Assembly Triumph 1
B Rocker shaft spacing washers. Austin Healey 2
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
glemon Final Rocker Shaft Question Triumph 5
glemon Tuftrided Rocker Shaft Triumph 3
glemon Opinion/Experence Rocker Shaft Wear Triumph 6
rlich8 "Oil Screw" on Rocker Shaft Triumph 6
ekamm TR2/3/3A Tr3 steering rocker shaft bushing Triumph 1
6 more about the rocker shaft Triumph 12
6 rocker shaft Triumph 3
L Rocker Shaft Assy Triumph 7
T Defective rocker arm shaft photo Triumph 12
T Rocker arm/shaft question Triumph 13
BOBBYR Rocker shaft rebuild Austin Healey 10
H Rocker Shaft assembly Austin Healey 1
chicken Rocker shaft Austin Healey 3
B Rocker shaft problem Triumph 2
T Rocker shaft cleaning Triumph 19
Moseso Rocker shaft dis/reassembly Triumph 3
Tinkerman TR2/3/3A Locking screw on rocker arm shaft, TR-3 Triumph 4
D Oil Spraying from Rocker Shaft - BJ 8 Austin Healey 10
M Rocker arm shaft question Austin Healey 11
Tinkerman 60 TR 3 post 60000 Rocker Shaft Pedestal Bushings Triumph 2
C Rocker arm play on shaft Austin Healey 12
M Rocker Arm Shaft Triumph 4
S GT6 GT6/TR6 rocker shaft oil problems. Triumph 5
Y TR6 TR6 - Secondary oil feed to rocker shaft Triumph 12
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
Hamish Racing General TR Rocker cover identification please. Triumph 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
H Rocker Cover Data Plate Austin Healey 15
Twit TR4/4A 1.5 in outside diameter rocker cover pipe Triumph 3
