Reinstalling Rear End in a BE - Quick Steps
Jim_Gruber
I face the prospect of needing to reinstall the rear end on Bugsy II on Saturday before loading on trailer. Got a dolly arrangement for a backup but would rather have on 4 wheels. Since I've never pulled a BE Rear end before, and don't know if all of the bolts are there. What really needs hooked up so I can get on 4 wheels for transport and loading. Here's what's back there now. now I need to reinstall LR Spring, attach radius rod and then attach rear end. Shocks and rebound strap Y/N. Trying to keep it simple. MOSS Catalog shows all of the parts and pieces but not how they all connect together.
PS - Shock and Spring. Radius Rod still bolted to Rear End
LS - Just Spring Mount Box/Plate. Assumption is radius rod bolted to rear end. Spring is not installed, still assembled but will need to locate parts and pieces needed to assemble to connect to rear end.
If you are just connecting it to make it roll, then use undersized bolts to make connections easier.
apbos
Jim Do you have both U bolts and the spring plate for the top of the unattached spring? Those the only non hardware store items you will need. I will get you a list of bolt and nut sizes for the rest later in the day. I got it almost completely laid out for reinstall on my car. Radius arms and springs should be all that you need to be attached. Make sure your drum will spin before hand.
Paul
Jim_Gruber
Jim_Gruber
Thanks Paul,
Looks like Nick found the can with the big bolts in it. What I can't yet confirm is if U Bolts and Spring plate is there. Radius arms appear to stil be attached to the rear end. Hopefully the braket the radius arm attaches to is still attached to the radius arm. Nick told me he'd go out and rummage in the parts to see if all else is there and might even see if he can fit it together for me. That would be a great help if he can at least validate all of the parts and pieces are there. This definitely will be a jig saw puzzle to solve. Bolts in this can look similiarly sized as what I fould on Bugsy with a 1/2 Elliptic Rear End.
apbos
Jim
I think a better diagram would be Moss UK at https://www.moss-europe.co.uk/Shop/ViewProducts.aspx?PlateIndexID=1182#30
A few critical things you will need are 2 - 3 1/2" 3/8 24tpi bolts to attach the one spring plate, the U bolt and nuts ( you might get away not having one or the other just to get it to roll)to attach that spring also. Two 3 inch 7/16" bolts to attach the axle to the springs and 2 to 4 7/16" bolts to attach the radius arms to the body and axle. Two are 3 inch and two are 4 inch. There is also a radius arm spacer that you will need at some time, but not to get it rolling. That will get you rolling.
P.S. The 3 inch 7/16 bolts that attach the axle to the spring and the axle to the radius arm are D capped bolts (when you are looking for them).
apbos
The bracket is still on the car. This got me organized Jim so at least I can put mine on the car in the next few days.
apbos
Here is a nice picture from 410 EAO that shows everything hanging.
nomad
The only thing that is critical is the spring to car attachment. The rest,as Trevor said, can be done with 5/16 bolts to get the car up on wheels and loaded.
Kurt.
Jim_Gruber
Jim_Gruber
Thanks Guys I forwarded this thread to Nick so he can try and locate all of these parts in the garage and cans of bolts and nuts. Getting closer.
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
Lin Reinstalling rear springs and axle in 64 MK2 Jaguar 1
J help with reinstalling the rear diffy on a 6 Triumph 8
KVH General Tech Reinstalling TR4A Interior Triumph 13
T TR4/4A How do you go about reinstalling cylinder head? Triumph 7
B Reinstalling 948 engine Spridgets 7
pkmh Reinstalling oil pressure gauge in a BJ8 Austin Healey 4
T MGA Grease axle stub before reinstalling hub on a MGA MG 2
T TR4/4A Prep before reinstalling TR4a gas tank Triumph 2
TRnorwegian Reinstalling the old Strombergs Triumph 2
TR4nut TR2/3/3A Question on reinstalling pinion flange on TR3A Triumph 8
T Reinstalling radius arms etc... Spridgets 4
zimmy reinstalling windshield Spridgets 1
G Reinstalling my Roller Rockers Triumph 4
B Reinstalling front springs. Spridgets 11
MGTF1250Dave Reinstalling Cylinder Head MG 3
M How Do I Set Timing On 1990 Marelli Ignition V12 after reinstalling distributor ? Jaguar 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
