TR4/4A Rear Turn Signals are Blinking In Reverse
KVH
My front turn signals work fine. My rear signals are blinking in reverse. Left goes when it should be right, and vice versa. I know this is an old refrain, but I've searched everywhere for a solution. Is there a pair of connectors perhaps hidden behind the gas tank panel that I can just switch? I'm not finding wires anywhere else that would be candidates for a fix. Thanks all.
Andrew Mace
It pretty much has to be that simple. I don't know where the connection(s) would be; all I can suggest is that you follow the green-with-white-tracer wire back from the RH lamp until you find a connection. Or follow the green-with-red-tracer wire back from the LH lamp until you find a connection.
KVH
KVH
Thanks, Andrew. I got it fixed finally. My switch apparently had the color coding reversed to how the wiring was installed in my car. For instance, the green/white wire was my right rear tail light, whereas on my switch the right tail lights were supposed to be the green and red stripe. I also then had to reverse a couple of wires up front near the front grill of the car. One thing is for certain – – this was trial and error and not any innate skill I possess. Thanks again.
J TR2/3/3A Add brake light to Rear turn signals Triumph 12
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
D Problems with left rear turn signal Austin Healey 11
A TR2/3/3A Rear turn signal bulbs Triumph 5
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
B How Free / rear wheels turn - XJS & Coil Question Jaguar 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
