TR2/3/3A Rear Sway Bar experience
PatGalvin
Hello all
I have a rear sway bar for the TR3A that I purchased many moons ago. (Addco is manufacturer). Does anyone have any experience running a rear sway bar and would you recommend it? My car already has a proper dose of oversteer, but I'm learning to handle it. Wondering is the rear sway bar will make that much worse and if it will help me corner a little flatter. Rear suspension is bone stock on this car.
Thanks for any suggestions.
Pat
CJD
Rear sway bar will increase oversteer...so don't do the rear sway bar unless you put an even larger one up front to balance it.
M_Pied_Lourd
Yeah, I have the Addco bars front and rear on mine Pat. They were installed on the car when it came to me as a retired vintage racer. I haven't pushed the car hard enough yet to test them, but I'm assuming the PO must have liked the set up a lot!
I do have the same type Addco set up on my TR6 and love the way it handles!
Cheers
Tush
TR3driver
Great Pumpkin - R.I.P
I had front & rear ADDCO bars on my TR3A and really liked the result on the street. Was part of an ongoing tuning exercise with wider wheels and sticky tires. IMO the ADDCO configuration gave too much oversteer, so I was working on toning it down when the car got wrecked. I used all nylon bushings at the front for a bit more effect. My next step was going to be having Richard Goode build a bigger front bar, but I never got back to that point.
However, it did seem faster around the track with the rear bar much looser (less effect) than I ran on the street. I picked up almost 2 seconds at the 2000 VTR autocross by loosening both rear link bolts by 1/4 inch or so and reefing down on the front ones.
The main advantage on the street, IMO, was avoiding the case where the inside rear suspension tops out (axle hits the frame) and suddenly picks up the wheel. The abrupt change transfers all the lateral force to the outside tire, which then slips and unloads the suspension, which plants the inside wheel again etc. The net effect is that the rear end skips sideways. But for whatever reason, that was less of a problem for me on the track and I had more trouble getting traction (with an open diff). YMMV and all that.
TRMark
Bronze
I have an Addco rear bar laying in some corner of the shop or out on the scrap pile. I put one on my 63 TR4 years ago when I used to autocross the car, lots of over steer. I considered myself fortunate I autocrossed before going a little hot into a tight corner playing in the twisties on a highway. Early TR suspensions are goofy. Positive camber for bias tires that like it in a world of radials that do not and frame rails running under the rear axle so it can pick up the inside wheel.
CJD
When you think about it...Leaf springs work just like a rear sway bay. Another reason a front bar should go on first.
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
S MGB Rear Sway Bar MG 2
Jim_Gruber Rear Sway Bar - Needed? Spridgets 10
M TR4/4A TR4 rear sway bar installation Triumph 15
W Spitfire Rear Suspension Sway Bar?? on 1980 Spitfire Triumph 5
M Tips for replacing Rear Sway Bar Bushings? MG 0
K TR2/3/3A Panhard or Rear Sway Bar on aTR3? Triumph 10
T TR6 TR6 rear sway bar question Triumph 6
T TR6 Is this a TR6 rear sway bar? Triumph 10
tinman58 TR2/3/3A Rear TR3 sway bar Triumph 5
heliguy TR5/TR250 Rear sway bar install, TR250 Triumph 1
D Lowering a RB: Keep or discard rear sway bar? MG 7
vping Rear Spring Swap & Sway bar MG 37
C TR6 TR6 Rear Sway Bar Install ?? Triumph 17
martx-5 TR2/3/3A TR3 Rear Sway Bar Triumph 12
B Spitfire Spitfire Mk1 Rear Anti Roll Bar / Sway Bar Triumph 3
rovernut MGB-GT MGBGT Rear Sway Bar installation MG 4
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
Got_All_4 Matching front and rear Anti sway bars Triumph 2
Nunyas '77 and up rear sway bars. MG 4
Nunyas Rear Anti-sway/Anti-roll bars... MG 6
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
