TR2/3/3A Question about TR3 Rubber Windshield Seal
Lbp
After five months in the body shop (I don't have a garage and no way to do body & paint work), I just got my '58 TR3A back with the body in showroom condition repainted in BRG. However, the newly installed rubber seal between the bottom of the windshield and the body of the car isn't sealing. It puckers up about 1/8" above the body in several places. The shop suggested that it will lie straight against the body after it has spent some time in the sun warming up. I question if this is correct as I tried speeding up the process with a heat gun with little success. Is there supposed to be some sealant to firmly attach the rubber seal to the body or is it supposed to be just a friction fit? Any info or suggestions would be greatly appreciated.
Bill
NutmegCT
I'm looking forward to reading responses to this. My lower windscreen seal has been 1/4" above the body ever since I got the car. Someone suggested it may have been mounted upside down or something. Heat has *never* improved the situation.
Tom
TR3driver
Great Pumpkin - R.I.P
Ditto. The wide part of the seal is not (or at least should not be) perpendicular to the section that goes inside the frame, so there is a definite back & front to the seal. But I'd swear I put mine in right, and it still doesn't lay down against the body as it should. Nor has that changed any in some 4 years stored outdoors in the SoCA sun.
mallard
I third the idea that the seal is on wrong, it needs to be flipped over. It should take one to two hours to do if all goes well. Some of the new seals are marked which way they should go.
Got_All_4
I would think the sun would expand it and make it wrinkle it up even more. For some reason my laid perfectly flat but leaked horribly in heavy down pours. I took a tube of clear silicon caulk and a very small bead just under the lip and it worked like a charm.
TR3TR6
When I put the new seal on mine, I had a gap on both sides. I had noticed that there were gaps on the old one before I removed it. I think that is why they say; they're a devil in the wet, because they sure do leak!
PKPoole
If the seal is contacting well everywhere but at the outer curves, then it is installed in the correct orientation. If it is barely touching along the center 'flat' section of the body, it is in backwards. The only way I've found to minimize the problem in the curves is to remove the windshield frame and while pushing the seal in the curve area toward the rear, put some silicon caulk in the front of the seal and hold it there until the silicon dries. This holds the seal 'rearward' and lets in make better contact. Be sure to wipe off any excess so it will not be seen when installed. Good luck.
Geo Hahn
This may be as good as it gets. I have never been able to get a perfect seal there -- and though a gap of an 1/8" or so doesn't look too bad, in a heavy rain you will feel like you're in a submarine that's been hit. Have towels (cloth or paper) handy.
Since you have a '58 I don't think you want to use any sealant to secure that edge as one of the great things about the earlier cars is how easily the windscreen slips off for a real wind-in-the-face experience.
The TRA Philosophy states "We believe that the person inside an automobile who is cold in the winter and hot in the summer--just like the weather outside--is a more healthy person"... they might have added 'and wet when it's raining'.
W TR2/3/3A TR3 Door Seal Rubber Question photo request Triumph 4
5 TR2/3/3A TR3 fender patch panel question Triumph 10
T TR2/3/3A TR3 Fuse Question Triumph 14
T TR2/3/3A Question on old radio from my TR3 Triumph 9
S TR4/4A TR3/4/4a Transmission rebuild question Triumph 7
T TR2/3/3A Question on TR3 thermostat from TRF Triumph 6
71TR6 TR2/3/3A TR3 floor pan to firewall question Triumph 2
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
D TR2/3/3A TR3 water pump question Triumph 4
BillyB62 TR2/3/3A TR3 timing/distributor question Triumph 7
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
T TR2/3/3A Question on paper air filters for TR3 Triumph 3
K TR2/3/3A TR3 body fitting question.... Triumph 3
J General Tech Quick Dist question. TR3/4 vs Heralod Triumph 12
toysrrus TR2/3/3A TR3 Heater Valve Question Triumph 5
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
Tinkerman TR2/3/3A 1960 tr3 a upholstery question Triumph 2
J TR2/3/3A Convertible Top Frame question for tR3 &3A Triumph 7
M TR2/3/3A Carpet question 1956 TR3 Triumph 9
T TR2/3/3A tr3 bulkhead holy question Triumph 13
Lukens TR2/3/3A TR3 SU carb question Triumph 10
Tinkerman TR2/3/3A 1960 TR3 A Additional steering question Triumph 4
T TR2/3/3A Question on side seal on TR3 fender seal plate Triumph 1
T TR2/3/3A having no shame I ask another question about a TR3 engine that is giving me fits Triumph 10
M TR2/3/3A TR3 fuel cap install question Triumph 9
T TR2/3/3A TR3 floor / frame mounting point question Triumph 13
Lbp TR2/3/3A New to Forum, New TR3 Owner, Dashboard Question Triumph 8
M TR2/3/3A One more steering question TR3 Triumph 4
Tr3aguy TR2/3/3A Hubcap Question TR3 Triumph 15
D TR2/3/3A TR3 brake rotor question Triumph 4
J TR2/3/3A TR3 oil pressure hose question Triumph 1
Russ Austin TR2/3/3A TR3 Transmission question Triumph 8
T TR2/3/3A tr3 brake/clutch reservior question Triumph 1
mgedit TR2/3/3A 56 TR3 Door Question Triumph 8
NutmegCT TR2/3/3A TR3 engine question Triumph 6
M TR2/3/3A My own TR3 windshield question? Triumph 5
toysrrus TR2/3/3A TR3 Interior Question: Triumph 5
PatGalvin TR2/3/3A TR3 Door Rebuild Weatherstripping Question Triumph 10
F TR2/3/3A TR3 interior mystery question- door pull handles Triumph 9
M TR2/3/3A TR3 Tail light question Triumph 4
M TR2/3/3A TR3 gas cap question Triumph 4
K TR2/3/3A TR3 Trunnion Question Triumph 2
J TR2/3/3A TR3 fuel pump question Triumph 7
R TR2/3/3A TR3 Headlight Wiring Question Triumph 6
af3683 TR2/3/3A TR3 Spark Plug Wire Question Triumph 11
C TR2/3/3A New member and newbie question on TR3 clutch Triumph 26
M TR2/3/3A TR3 steering column mounting question???? Triumph 2
Brooklands TR2/3/3A TR3 Turn Signal question... Triumph 6
J TR2/3/3A Aftermarket starter for TR3 question Triumph 8
