Hi Everyone, I have just statically set the ignition timing on my TR3A with the radiator removed (3/8" BTDC on the crankshaft pulley mark) During the first road test the car was pinking really badly going up any sort of hill. I've retarded the timing 1 complete turn on the vernier (in increments of 1/4 turn) and I'm still getting a lot of pre-ignition noise. Does this sound normal & should I retard it even more? What fuel do these engines run on best? I am using regular gasoline, should I be using premium? For the record the car is fitted with a TR4A cylinder head with SU HS6 carbs, 86mm pistons and a Crane XR700 electronic ignition. The auto advance springs in the distributer are new (moss) and the vacuum line to the carbs is not leaking. Many thanks Neil.
