TR2/3/3A Pops out of 2nd gear
doc50
I'm working through my list and am down to this problem:
My rebuilt (A type OD, full synchro) trans has always popped out of 2nd gear on deceleration. It doesn't matter if I'm backing off hard or easy, it will pop out. I just have to hold back on the shift lever with a few pounds of pressure to keep it in gear.
I'm hoping it is something in the top plate that I can fix without pulling the trans. The trans was rebuilt by a shop and I acquired it with the 8 boxes of parts when I bought the project.
Thanks anyone for scratching your heads on this one.
Thom
1959 TR3
#34909L(O)
M_Pied_Lourd
I'm no expert, but sounds like maybe a bad 2nd gear top hat bushing or a bad detent (plunger and spring) in the shift linkage under the top cover.
Cheers
Tush
TomMull
The top unit will come right off. Check detents as Tush suggests. Check also for a worn fork. Tom
TR4nut
Had the same issue, I was convinced it was a broken 2nd gear bush. It wasn't. Readjusting the detent spring fixed it.
doc50
doc50
Thanks, guys. I'll take the top off to see if it's an easy fix.
nb: How to adjust the detent spring?
Thom
1959 TR3
#TS34909L(O)
mgedit
In my non-OD transmission that I rebuilt in my 73 TR6, it would do just as you describe with redline fluid. Switched back to non-detergent 30 oil, and the issue went away. What fluid are you using? Cheers, Mike
doc50
doc50
After much discussion with Ken Gillanders (who I believe is still one of the real authorities on these cars), I went with Valvoline 20-50 Racing oil. I had to be convinced but Ken saw much less brass wear after he experimented with several types of fluids.
It sounds like this problem (and the solution) still raises questions.
Thom
1959 TR3
#TS34909L(O)
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
O TR4/4A tr4 pops out of second gear on deceleration Triumph 13
doc50 TR2/3/3A pops out on downshift Triumph 6
W pops out of second gear on acceleration Austin Healey 12
6 Pops Bugeye lives Spridgets 16
Team_Sprite A happy little street car pops up again Spridgets 5
6 Pops Garage Up-date Spridgets 21
6 Pops Bugeye, Thrash Sesson Spridgets 13
Bill Redd Top pops! Triumph 12
K trans pops out of gear Austin Healey 13
SCguy Hood pops open Triumph 4
skinsgamer Speedo cable pops off the tranny Spridgets 8
S Door Pops open unexpectedly MG 5
T General TR Another trans popping out of 2nd Triumph 14
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
M T-Series MG TD 1st/2nd sliding hub end play MG 1
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
W TR6 Seat diaphragm failure on 2nd seat! Triumph 8
W Find gearbox rebuild [2nd synch shot] South. California Jaguar 1
AUSMHLY Shifting into 2nd, problem because of the Flywheel? Austin Healey 21
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
DerekJ Jack Rawles Racing at Zandvoort. From 6th to 2nd. Austin Healey 4
TR3driver TR4/4A New document available - TR4A Spare Parts Catalogue 2nd edition Triumph 5
Lotus Club SoCal 2nd Saturday Breakfast – Lotus Club of SoCal Activities Planning Meetings Lotus 0
M TR2/3/3A 2nd commission [vin] number??? Help. Triumph 12
Csarneson Source for BN4 2nd Gear Austin Healey 8
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
H 1st and 2nd gear problems Austin Healey 5
glemon TR5/TR250 Tranny Won't go into 2nd TR250 Triumph 13
B 2nd gear blocking ring failure BJ7 Austin Healey 5
F 2nd set of detail questions: 1963 BJ7 Austin Healey 21
Coyote1 2nd Gear OD or Not Triumph 19
dougie Cali Healey Owners - Sonoma June 2nd -5th Austin Healey 9
Jim_Gruber 2nd Grease Fitting on Fulcrum Pin Spridgets 5
bigjones TR2/3/3A TR3/4 clutch adjustment and shifting into 2nd Triumph 5
EricG Sunbeam Gathering- Oct. 2nd, Columbia,SC Sunbeam (Rootes) 0
R lost 1st and 2nd! Spridgets 10
regularman 2nd condenser in a short time. Spridgets 13
B Last Green Valley Rallye, May 2nd Jaguar 5
H jumping out of 2nd gear Austin Healey 3
AUSMHLY Youtube...Finished my 2nd video....007 Healey Austin Healey 16
theleisure 2nd Gear, Please Don't Go Away! Spridgets 8
J Downshifting from 3rd to 2nd Austin Healey 7
T 2nd day of Amos Triumph 24
D no syncro 2nd advice MG 13
