Polished Metal Coating to Protect Shine
dmorris1
Member
Hi Everyone,
I am polishing some metal on the throttle linkage and wondering what is the best sealant or coating to apply to keep the shine.
David
dougie
You want to apply a 2k hi-gloss urethane. Without paying through the nose for quart of automotive high gloss, activator and reducer, the best alternative is from Eastwood products. https://www.eastwood.com/spray-max-2k-high-gloss-clearcoat-aerosol.html This would be the best (ease of application) method to clear coat your parts in a professional manor if you don't have the necessary spray equipment. After polishing said parts, I would suggest a complete and thorough wipe down with denatured alcohol with a clean cotton rag to remove any residual polishing compounds. Change the rags often if you have a lot of parts or contamination.
Nunyas what to use on polished aluminum Restoration & Tools 4
TulsaFred Polished stainless steel bumpers? Spridgets 13
D Polished Aluminum Protectant Spridgets 4
S TR4/4A polished center panel for 62 TR4 Triumph 3
bugedd Clear coating polished aluminum Spridgets 26
britndablood BT7 polished or painted windscreen post Austin Healey 12
C 45 shipped in the USA brass over flow, Polished Spridgets 5
G MGB MGB Port and polished head MG 3
M Jeffs micro polished carb pictures wanted Triumph 4
W Polished cockpit trim Spridgets 18
theleisure Polished Radiator top vs. Painted top Spridgets 9
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
D Made a sheet metal break. Restoration & Tools 5
J Door Draught Metal Clips Austin Healey 4
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
F Off Topic metal forming for a friend Triumph 25
N Spridget sheet metal Spridgets Classified 0
steveg TR6 Metal Dash - does anyone make one? Triumph 13
J For Sale Triumph TR 2/3MISC sheet metal parts Triumph Classifieds 1
Busted knuckles TR2/3/3A Sheet metal question, Triumph 5
jfarris TR2/3/3A Metal washers for SU H6 float bowls Triumph 1
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
red57 Metal prep of chassis after repairs and shot blasting Austin Healey 5
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
71TR6 TR2/3/3A Moving a radius on sheet metal patch Triumph 12
S TR2/3/3A busted through to bare metal Triumph 18
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
SpeedyG TR4/4A TR4 vs. TR4A metal dash panel Triumph 5
S TR2/3/3A were the 2 metal gas lines connect Triumph 18
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
S TR4/4A Metal facia trashed Triumph 3
R metal adhesives Austin Healey 12
Editor_Reid Metal [or maybe fiberglass] tonneau for Healeys Austin Healey 24
Tinkerman TR2/3/3A 1960 tr3a sheet metal fitment Triumph 6
C Recommendations on where to send my 1954 BN1 for metal work? Austin Healey 13
T TR2/3/3A TR3A Sheet Metal Piece Needed Triumph 2
I General TR Pot metal rechroming Triumph 7
T TR2/3/3A Requesting some Pictures for metal work Triumph 9
MTribe TR6 Can you identify these metal shavings in the oil? Triumph 32
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
Brinkerhoff MGA metal work details MG 18
certifiedcarnut Spridget master cylinder cap, metal Spridgets 8
S TR2/3/3A Odometer gears for the early pot metal speedometer Triumph 27
Scot1966 TR6 TR6 sheet metal Triumph 3
D Another question 1967 BJ8 top installation,metal retaining strip Austin Healey 1
T TR4/4A Fabricating a metal panel in between the fuel tank and cockpit Triumph 6
G Filler metal used for tig welding ah aluminum shrouds Austin Healey 2
JPSmit New fun tool review - metal tumbler Restoration & Tools 6
