Nunyas
I recently bought a pair of pneumatic tools (CH... they were on sale in addition to Osh paying the sales tax! less than $30 each!): an impact wrench, and a ratchet. I found that the aircompressor that I have access to doesn't seem to supply quite enough juice when I set the pressure to 90. I was wondering, how in advisable is it to turn up the pressure to 100 or even 120 to be able to deliver the flow rate needed while the triggers are pulled?
Also, is it possible to repair a quick disconnect/connect fitting on a hose, or is that one of those parts that you just replace when it goes bad? The fitting seems to leak a bit if the hose to tool connection isn't positioned "just so"...
Thanks for any input guys!
