General Tech Pedal freeplay
Platinum
Something usually overlooked are the clevis pins and actuating rods when trying to bleed brakes or clutch hydraulics. Over the years we've found numerous cars with ovaled out rods and worn clevis pins, causing so much "slop" in the mechanical parts that actual travel at the "business end" of the systems is reduced significantly. Something to pay attention to. Case in point are the pins in the photo, from two different customers' cars. Excess freeplay was quite evident in both but the owners couldn't find the reason they weren't getting a full pedal.
Grantura_MKI
Typical wear from usage. I usually replace clevis pins and push rods top and bottom. When you factor in the lost throw from both being worn it amounts to half of the action.
Madflyer
Good point above can be a shifting problem in TR's. I make my pins from shoulder bolts by cutting off threads and drill cotter pin hole. Madflyer
vping
Bronze
Yeah. Add up all the slop in the pins and you could have nothing at all.
Had this happen in my BGT. The DPO left it for dead with clutch problems (none) when I found it and towed it home. Pins looked like crankshafts they were so bad. I replaced the pins and the clutch worked fine. I still have it hanging on the wall of shame with some other interesting stories.
Platinum
We had quite a few "Wall of Shame" bits 'n pieces in the shop. And you're right about the stories. Many are "How did you NOT notice something wrong?!?"
vping
Bronze
LOL. Maybe I'll start a "Wall of Shame" post!!
Yeah, I will!
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
F Excessive Brake Pedal Travel Austin Healey 3
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Sopwith_Camel MGB pulsing brake pedal MG 10
CARSINC MKIII Accelerator Pedal Spridgets 0
Gatheringtree TR2/3/3A Billet Pedal Cover Set w/ Triumph logo Triumph 0
P Pedal Position Adjustment Austin Healey 2
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
T Clutch Pedal Engagement Point Austin Healey 1
K TR2/3/3A The Dead Pedal Triumph 3
petnatcar Dead Pedal Austin Healey 12
R TR2/3/3A Gas pedal pad for TR-2 Triumph 3
bighealeysource Soft Brake Pedal Austin Healey 7
BierRunner TR6 TR6 Gas Pedal Triumph 4
DrEntropy MGB Pedal extension MG 6
Jeepster Clutch Pedal Position Austin Healey 4
S Receding Brake Pedal Austin Healey 32
C BN1 Clutch Pedal Rattle Austin Healey 2
J For Sale Triumph Tr 2/3 Gas Pedal Triumph Classifieds 1
G TR6 Binding Clutch Pedal Triumph 5
K Midget Brake Pedal Question Spridgets 2
D TR2/3/3A clutch/brake pedal question Triumph 4
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
D Gas Pedal Pad Jaguar 7
K For Sale TR3 Pedal Box Triumph Classifieds 0
P TR6 Clutch pedal click noise Triumph 2
S TR2/3/3A clutch pedal connection hole Triumph 9
steveg "Sticking" the brake pedal Austin Healey 3
P TR6 Clutch pedal noise Triumph 2
B TR2/3/3A Where on the clutch pedal? Triumph 4
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
K For Sale TR3 Accelerator pedal assembly Triumph Classifieds 1
K For Sale TR3 pedal box Triumph Classifieds 0
D mystery of the day... pedal block? Austin Healey 5
tomshobby TR6 power assist for clutch pedal Triumph 12
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
M Throttle pedal problem Austin Healey 8
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
Jim_Gruber Pedal Box - Reassembly - Any issue with adding a spacer in the middle of the pedals Spridgets 5
A Throttle Pedal Height Austin Healey 17
simon1966 Pedal box blanking plate for a RHD Frog Eye Austin Healey 5
Michael Oritt Brake pedal contact or mercury switch Austin Healey 19
S TR2/3/3A gas pedal rod Triumph 2
B TR6 TR6 clutch pedal height Triumph 2
petnatcar DEAD PEDAL for a BT7 Austin Healey 25
Rut Pedal box blanking plate Spridgets 10
AngliaGT Tossing Out Old Issues of Sports Car/The Wheel/Loud Pedal Racing 1
H BN1 Brake Pedal Hitting The Downpipe Austin Healey 9
AngliaGT Early '74 Midget - MC/Pedal Box Replacing Spridgets 3
