Painting the car
jcsb
Ok, so I am in the process of converting to the Smitty Toyota transmission. I've decided I would rebuild the engine while I'm at it. While I have the engine/transmission out I thought about sending the car to be painted. Any thoughts on whether this is a good stage to do this or whether I should finish and re-install the engine/transmission? I am hoping to have the car for spring/summer.
John
Healey_Z
Painting a car can make a real mess with dust and over spray, especially in the interior and engine compartment. I like to have it painted, the detail the engine compartment, then install the interior.
It's best to paint a bare shell if possible, less masking and overspray concerns. So paint while apart if possible. But you need to ask yourself how far you're going to go with it. Good paintwork means a lot of prep work for the base body ensuring there are no waves in the panels, rust, dirt and so on. This prep can take a lot of time, effort and money to do right go get a top notch finish. And if you do some parts, will you notice other bits with an older perhaps no longer as nice finish?? And what's the budget, as you can find prep and paint can quickly cost more than you thought.
Hawkscoach
John, I have asked a lot of assembly/mechanical questions on here, so this may be my opportunity to provide help. What I have done in the past on other projects and applied to my current AH project is to remove everything (document as much as you can); find and fix all the rust and/or damage (you may already have done this, however, there are always surprises and now is the time to fix them, correctly), a rotisserie helps so much to us older guys; Do all the panel fit/adjustments/welding, etc. (spend the hours here. I had panels on and off so many times I lost count); Once you are completely happy that panel fit is perfect and not until then, remove all the panels and prime/paint the scuttle; If you are sending the work out, you will have a zillion mechanical parts to clean/replace/rebuild so that once the scuttle is painted, you can start the reassembly process. Hope this helps as a summary. Books can (have) been written about this so I attempted to summarize (and I know this is obvious to many, but not to someone new to the restoration effort) fyi, my Camaro took 8 years and the AH is going on three years. The point is you have to decide how far you want to take it based upon time, skill, and most importantly, money................good luck. Doug
J
jcsb
Ok, so the decision has been made. I plan to finish all the mods which include (4 wheel disc brakes, tandem master cylinder, tandem brake booster, stainless brake and fuel lines, and other misc. mods) so that I will have all mounting holes done. I'm finished with about half and should have the rest finished in about 2-3 weeks. I need to machine some special mounts for the tandem brake booster and master cylinder plus finish fabricating the brake and fuel lines. Then it gets shipped to the body shop. The body is the one thing I'm not doing so when it returns I should be assembling parts and not drilling holes for mounts or making modifications.
John
Keoke
Call the guys @ Absolutely British and have them do it for you
J
jcsb
I wish I could find someone local so that I could be available to answer questions and keep up with what's happening.
John
B Painting the Car - Corner Bead Advice Austin Healey 21
T TR6 Painting the car with the fenders on Triumph 7
B Final painting of all body panels - with panels on or off car? Pros and Cons? Austin Healey 7
R TR4/4A Painting engine in the car Triumph 7
K Painting a car not stripped to bare metal? Triumph 6
Tabcon Car painting question... Triumph 19
tahoe healey Painting my car Austin Healey 6
F Car Painting... Triumph 6
H Painting fiberglass car question Restoration & Tools 4
B Painting the bumpers on a rubber bumper car MG 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
LAW75 Painting the Grille Surround Austin Healey 12
J Shroud Painting ["Finally done with these"] Austin Healey 3
GeorgeC Painting the Battery Austin Healey 0
J Painting Underside of Shrouds Austin Healey 13
J Painting a Frame and Substructure Austin Healey 12
Jim_Gruber Bugsy IV - Painting, Cutting, Buffing is done Spridgets 20
S TR2/3/3A painting the floors of my tr3. Triumph 2
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J TR2/3/3A Painting floor pans Triumph 2
S TR2/3/3A Painting the body tub exposed parts again Triumph 19
J TR2/3/3A Painting Triumph 11
S TR2/3/3A how to position pieces when painting Triumph 7
T TR4/4A Painting front hubs Triumph 2
S TR2/3/3A tr3 painting --spraying: vertical, horizontal ect... Triumph 8
69MGC T-Series MGTA Digital Painting 2 MG 0
B TR6 TR6 Painting/Restoration Triumph 2
69MGC MGC MGC Digital Painting MG 0
69MGC AH 3000 Digital Painting Austin Healey 0
69MGC Newest Digital Painting Aston Martin Other British Cars 0
B TR6 Painting a '74 TR6 Triumph 1
H Healey 100 Painting Austin Healey 5
KVH General Tech Questions About Painting Triumph 6
kennypinkerton General MG Rostyles. Painting question. MG 2
KVH General TR Painting the Engine Compartment with Spray Can Triumph 3
S TR2/3/3A painting the body tub “inside” Triumph 31
S TR2/3/3A I hate painting Triumph 8
J Final painting detail questions Austin Healey 16
dcoplan Suggestions for painting letters on dash knobs? Spridgets 6
Bob Claffie MGB Painting rubber bumpers MG 4
B Painting underside of front and rear shroud - Original prep and color? Austin Healey 3
madhouse Painting Wheel Wells of my 100-6 Austin Healey 8
drooartz General Tech Painting my Rostyle wheels MG 7
Lbp TR2/3/3A Painting Help Needed for Restored Steering Wheel Triumph 5
J Painting transmission Austin Healey 7
glemon New Painting Method Restoration & Tools 2
Jim_Gruber Painting inside a BE Boot Spridgets 8
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
Brinkerhoff Painting or dyeing to change interior color? Restoration & Tools 2
D Live and learn… then learn some more… [painting] Spridgets 28
